Home › Forums › Products › Stompboxes › WIRING DIAGRAMS H90 DUAL OR INSERT
- This topic has 2 replies, 2 voices, and was last updated 1 year, 8 months ago by
croalex.
August 12, 2024 at 6:02 am #184218
August 12, 2024 at 7:21 am #184220
First diagram: Yes, the signal flow works but since the H90 lives post-preamp I feel the splitter and parallel mixer are both unnecessary. If you send a mono signal to the H90 on Insert mode set to parallel routing, the H90 will internally split that signal to each effect and output from each algorithm in stereo anyway. Plus, you’d have the added benefit of using the H90’s stereo fx loop to add an external effect without committing to it living on either path of the hardware mixer.
Second diagram: This gets closer to what I was talking about in the first diagram. I do not understand the benefit of the splitter here. If you go straight into Input 1 of the H90 from the output of your preamp (after the Sentry) in mono, the H90 takes care of splitting that signal internally. It’s not necessary to use the Insert in the manner you’ve laid out if what you want to do is run effects in parallel. The H90 does it automatically.
August 12, 2024 at 8:40 am #184221
Ok
but i don’t understand the internal routing of the H90?
In first diagram the benefit of a parallel blender is to activate or disactivate the path 1 or path 2.
I have the possibilitie to mix directly(in live) in my pedalboard the dry signal with the path 1 and 2.
In the second the same thing,activate or disactivate the two paths with the splitter.
I always use the external preamp/distortion/compressor/ (never pre post effects of the H90) and the effects i only use in H90 are: chorus/delays/reverbs/pitch.
In the different two paths i have different effects…example:Filter Pong+Space Time.
I think for me this configuration works probably in live and in home studio for recording with the Two Notes Torpedo Reload.
Actualy i have two H9, an old Eclipse and i use a H90 of a friend…but i want to buy one H90.
If you have a good diagram in a box(H90) to use for my case without mixer,splitter, in stereo configuration…
See my basic equipement in attached file.
Thank you and escuse me for my bad English…i am French.
Alexandre
