Home › Forums › Products › Stompboxes › Swapping in 1.2.2.46
- This topic has 4 replies, 4 voices, and was last updated 3 years, 3 months ago by
tonyshred.
January 8, 2023 at 6:34 pm #168367
Hi there,
New Features in 1.2.2:
• Add support for preset swapping from H90 Control
how do I do this ?
I also get no “graphic” feedback, when I swap on the hardware…
I’m 1.2.2.46 btw
January 9, 2023 at 3:08 pm #168380
Hi Kosi
Add support for preset swapping from H90 Control how do I do this ?
In the Edit window of H90 Control, on the same line as the title of the Program, on the right, there are two arrows pointing in opposite directions; it’s next to the “i” icon. Press that and it will take the current algorithm in Slot A and put it in B, and take B and put it in A.
If you are swapping on the pedal while you are in Routing mode, you can see the algorithm icons change positions on the signal flow graphic. If you happen to be connected to H90 Control while you make the swap on the pedal you will see the algorithms switch positions on the app as well. As you swap within the app, if the pedal is in SELECT mode, you will notice the preset names swap in realtime. Similarly, if you are in PERFORM mode, you can see the mapping from one switch go over to the other footswitch each time you Swap.
January 31, 2023 at 3:39 am #168761
Is it possible to swap algorithms A and B on the pedal without connecting to H90 control? I can’t seem to find it.
January 31, 2023 at 7:04 am #168763
In Routing mode, press Quick Knob 1. There’s a tip box for it in that section of the manual: https://cdn.eventideaudio.com/manuals/h90/1.1.2/content/edit-modes/routing.html
January 31, 2023 at 8:36 am #168764
Awesome. Thanks.
