Home › Forums › Products › Stompboxes › Sound Difference Series vs Parallel with only 1 preset being used
- This topic has 7 replies, 5 voices, and was last updated 2 years, 10 months ago by
carouzal.
June 9, 2023 at 9:16 am #171832
So this morning while playing with my H90 I noticed something that seems strange.
I am in dual mode, I added a flanger preset to the program in slot A, Slot B is thru.
Using the routing control the same preset sounds completely different when I have the flanger in path B series vs parallel.
I would think that with only one preset being used, the other is set to thru that the sound would be the same.
Am I missing something here or is this expected?
June 9, 2023 at 9:24 am #171834
Can you give us some more insight into your setup? I know you’re using Dual mode, but are both presets on the same path or is there a preset per path? What Bypass Mode are you using? Are both sets of outputs,1&2 and 3&4, hooked up to the same type of input? Are you running all I/O at the same operating level?
June 9, 2023 at 9:25 am #171835
Can you be more specific when you say it sounds completely different? If your presets are routed in parallel and one of them is a Thru preset, that is essentially create a separate dry path, so it should sound different than Flanger + Thru in series (in parallel, there will now be a lot more of the dry signal). If you turn Kill Dry on and bypass the Thru preset in parallel, that should sound more similar to the series routing.
June 9, 2023 at 10:06 am #171836
Bothe Flanger and thru are in path B. All inputs / outputs are set to instrument level, same operating level.
The added dry signal makes sense, I will try a few more things when I have a chance and report back.
June 9, 2023 at 1:44 pm #171847
Yeah, this is very likely a case of phase cancellation and filtering because the dry single is being mixed with itself and a time based effect among other timing and frequency anomalies.
June 10, 2023 at 6:14 pm #171870
I’m having the exact same issue.
It doesn’t matter the effect, but if I have any 2 effects in series and bypass one effect. Then when I switch to parallel with the same effect bypassed its sounds different than the effects in series and one bypassed.
Roy
June 12, 2023 at 10:18 am #171905
Have you tried turning kill dry on? This may work better for you when you are using effects in parallel.
June 12, 2023 at 10:25 am #171907
I have not had time to play with this after my initial post but I will ask a general question.
Im new to being able to run effects in Parallel, I do seem to like Reverbs and Delays split this way though.
Do I want dry signal in both presets when doing this? Or should I only have dry signal in one preset.
Really my plan is not to run a thru setting in parallel with another preset it was kind of an accident and was curious why the sound different.
