- This topic has 7 replies, 4 voices, and was last updated 2 years, 10 months ago by
wvought.
June 28, 2023 at 3:43 pm #172210
I’ve gotten into the habit of sidechaining vocals to a compressor on my reverb send in Cubase. Easy to set up, and it causes the reverb to duck when a vocal phrase starts. The reverb then blooms when the vocal phrase stops.
Is this possible in the H9000?
Thanks.
June 28, 2023 at 5:30 pm #172215
Try this:
#9411 Dynaverb
https://cdn.eventideaudio.com/manuals/h9000/2.0/content/appendix/algorithms/94_Space.html
June 28, 2023 at 5:44 pm #172216
Thanks.
But (oops) I think I should have specified that my intended use in this case is sending a stem (analog) out from my interface, then to the H9000, then to a summing mixer. So the H9000 would be used as an insert, not a send, which I think rules out using a sidechained compressor.
June 28, 2023 at 6:07 pm #172217
Hmm, I guess I don’t understand your signal chain/intent. Insert on just the vocals, yeah?
June 28, 2023 at 6:23 pm #172218
Yes, but I think my original question was a bit lame. I should just use a send within my DAW.
June 28, 2023 at 11:44 pm #172221
You could build a chain with a compressor feeding a reverb in the H9000, the same way. Just use a third buss input as the side chain.
Alternatively I built a dynamic send algorithm that can send to different algorithms depending on the signal level.
https://godlike.com.au/index.php?id=420
I could modify it to have an external side chain pretty easily, if you think it would be useful.
June 29, 2023 at 9:21 am #172228
Theres a sidechain compressor algorithm you can check out here: https://www.eventideaudio.com/forums/topic/dual-stereo-sidechain-compressor/
Alternatively, there are many ducked delay algorithms that you may find useful for this.
June 29, 2023 at 2:08 pm #172234
Thanks to all who responded. It will be next week before I really have a chance to look into all of this.
I tend to find I/O routing difficult to understand, so please bear with me. 🙂
