Home › Forums › Products › Stompboxes › Send MIDI Clock from iPad to H90 – via USB C?
- This topic has 6 replies, 3 voices, and was last updated 2 years, 3 months ago by
Eventide Staff.
January 14, 2024 at 9:15 am #177278
Since MIDI Clock doesn’t like to be send wirelessly (so no MIDI Clock via Bluetooth),
I thought that I might be able to send MIDI Clock via a USB cable (iPad = Lightning, H90 = USB C).
However, this doesn’t appear to be working.Anyone any experience with this?
January 14, 2024 at 12:07 pm #177280
Correct, no MIDI clock over Bluetooth since the connection speed is not fast enough to be accurate.
You can send clock via USB. Make sure you have configured the H90 to use MIDI Clock in the Tempo Menu, and that the clock source is USB.
https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/tempo-menu.html
https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/system-menu/midi.html
January 15, 2024 at 8:47 am #177289
Yes, but can I send MIDI Clock from my iPad (via its lightning port) DIRECTLY to the H90 (via its USB-C port)?
That way I only need a default iPad cable between those 2 devices (lightning to USB-C). -
January 15, 2024 at 2:23 pm #177296
Yes, the H90 can take midi lock on its USB port. It doesn’t matter if the cable is USB 2 or USB C.
You would set this up in the midi host program (DAW) sending the clock.
January 15, 2024 at 4:31 pm #177299
And can use my iPad instead of a DAW?
January 15, 2024 at 4:49 pm #177302
What are you trying to accomplish? Because it doesn’t usually make sense to send a midi clock unless you are trying to sync different devices.
You would need a program that could generate & send midi clock. Maybe Garageband can do this – I’m not sure.
January 15, 2024 at 4:58 pm #177304
I’m not sure if this will work with the direct lightening to USB C cable. You may need to use a dongle/adapter to your iPad for this to work properly, such as this: https://www.apple.com/shop/product/MK0W2AM/A/lightning-to-usb-3-camera-adapter
What iPad app are you using on your iPad to send MIDI clock? Does the H90 show up as a MIDI device in the app when you use the lightening > USB C cable? If not, then you’ll probably need to use the adapter.
My iPad has a USB C connecter, and the direct USB C > USB C connection works with the H90. You can use Logic Pro or other applications to send MIDI clock this way.
