- This topic has 13 replies, 7 voices, and was last updated 1 year, 4 months ago by
tlongabaughEventide Staff.
June 20, 2024 at 3:52 am #183366
The installer says it’s going to install into Steinberg/VST2 then it completes immediately without installing anything.
Run it again and it just hangs……
Not exactly seamless. Any suggestions in getting Saturate downloaded?
June 20, 2024 at 11:32 am #183370
Sorry for the issues you are having. I just tried running the latest Saturate installer and it worked correctly for me.
What OS or Windows version are you running?
Have you checked the plug-in folders for Saturate, or is the plug-in just not showing up in your DAW?
What DAW are you using?
June 21, 2024 at 2:12 am #183380
Hey thanks for the reply.
I’m running Reaper on Windows 10.
Reaper is configured to scan for plugins in the following folders:
C:\Program Files (x86)\Steinberg\VstPlugins;
C:\Program Files (x86)\Common Files\VST3;
If I try to install only the VST2 version, the installer targets C:\Program Files\Common Files\Steinberg\VST2\Newfangled Audio. However after it has completed, no such folder exists.
If I try to install the VST3 version, the destination folder screen in the installer is blank. Hitting Next goes straight to the Finish dialog, but nothing has been installed.
I have the Ultrachannel plugin installed in C:\Program Files (x86)\Common Files\VST3\Eventide. This works great. If possible I’d like to get Saturate VST3 installed here as well
June 21, 2024 at 2:21 am #183381
**EDIT**
So I managed to get the VST2 version installed. However I’d like to get the VST3 version but the screen that allows to specify the destination folder is blank
June 21, 2024 at 12:47 pm #183385
Can you please try running the uninstaller from Add or Remove programs and then try running the installer again?
June 22, 2024 at 1:31 am #183417
Thanks for your suggestion.
I think my initial problem was that the installer was defaulting to C:\Program Files\Common File and not C:\Program Files (x86)\Common File where Reaper was looking.
I’ve also managed to get Equivocate VST2 installed successfully (but same issue trying the VST3 install) so now I’m up and running I’ll just stick with the VST2 versions and leave the VST3 conundrum for another day.
Cheers
July 4, 2024 at 12:59 pm #183579
Same issue for me, the installer does not install a thing! Can you please provide a fix? Thank you!
July 5, 2024 at 1:07 am #183588
Check that the installer target directory is on the list being scanned by your DAW. This was the issue for me, I didn’t notice the installer was targeting C:\Program Files\Common File and not C:\Program Files (x86)\Common File.
Can’t help with the VST3, I couldn’t get that one to install so just running with the VST atm
July 5, 2024 at 9:02 am #183591
Yepp, checked that. There is literally no file installed within the spicified directory. Also VST 3 ist no installed.
OS is WIN 10 and DAW is Bitwig.
October 24, 2024 at 10:21 am #185748
same her dosent instal on the adress just the uinstal exe
December 1, 2024 at 5:29 pm #186554
I’m having the same issue
December 3, 2024 at 9:15 am #186577
Hi, if uninstalling the version of Saturate on disk and installing the latest version from here doesn’t solve the issue, please email support@eventideaudio.com with the following info, and we can assist you further:
- OS version
- DAW version
- Screenshot of C:\Program Files\Common Files\VST3
- Screenshot of C:\Program Files\Common Files\Steinberg\VST2
- Screenshot of activations in the iLok License Manager
December 14, 2024 at 5:39 pm #186982
Same issue. Ableton 12, Windows 11
December 16, 2024 at 1:31 pm #187043
Hi, please email support with the above mentioned info and we can assist you further.
