Home › Forums › Products › Stompboxes › Routing on H90 in different modes
- This topic has 3 replies, 2 voices, and was last updated 8 months, 3 weeks ago by
joecozzi
Eventide Staff.
August 7, 2025 at 4:33 am #191418
Just got my new H90, want to pair it with my quad cortex. After checking the manual, I’m not sure if I understanding the unit correctly so decided to make a post for help.
My idea is to run quad cortex as my main and put H90 into the FX loop of it. I’m putting 2 devices on a pedalboard, so planning how to connect them is critical because I’m not changing the routing that often.
I found a picture shows the H90’s I/O is configured to adapt which port you’re using. So here are my cases:
- If I’m using I/O 1&3 on H90 to send&return 1&2 on QC. H90’s signal should be in mono
- Insert mode: disable insert 1, using only the main signal chain on H90 should work as a single FX loop block in QC. But what’s going to happen if I use insert 1 as another FX loop in QC? Insert works as part of the signal chain in H90, I can’t figure out what will happen if I using it as FX block in QC.
- Dual mode: I get path 1&2 in mono, easy to understand. In QC I can use 2 FX loop blocks representing path 1&2 and put them anywhere in the signal chain.
- If I’m using I/O 1&2 on H90 to send&return 1&2 on QC. H90’s signal should be in stereo
- Insert mode: same as using I/O 1&3 except the main signal chain becomes stereo without any insert.
- Dual mode: only path 1 is available but it’s in stereo, which makes no difference to insert mode above.
I’d like to know if my understanding is right, there are just too many possibilities!
August 7, 2025 at 10:21 am #191430
I would like clarification on this. In this scenario, would you be using the H90 in Dual routing mode? If so, you can use the H90 as two independent mono processors. Path 1 of the H90 (I/O 1) would use QC Send/Return 1 and Path 2 of the H90 (I/O 3) would use QC S/R 2. If you are using Insert mode, the factory default, you may only use Output 1 for mono operation. If you use Out 3 or Out 4 it’s assuming your connecting the QC as an external effects processor, probably not what you want.
The H90 inserts are designed to allow you to place external effects within the H90’s signal chain. In other words, you would be able place QC processes anywhere within the H90 signal chain. Of course, you would be required to route things in the QC so they don’t interfere with the normal signal flow, otherwise you could create a nasty feedback loop. It’s more common for QC users to use Dual Routing mode and place each H90 path on it’s own FX Loop on the QC.
2. Dual mode: I get path 1&2 in mono, easy to understand. In QC I can use 2 FX loop blocks representing path 1&2 and put them anywhere in the signal chain.
Sounds like you are using two mono FX loops on the QC for stereo audio. Is there a way to link QC FX loops 1&2 together for true stereo functionality? I’m not familiar with the QC well enough to know if it’s possible. The reason it’s important is how it treats the stereo image (does it pan the signals appropriately?). The QC manual should tell you.
No, if you are using I/O 1&3 you will not get stereo audio. You may actually break the signal path because Out 3 is used to send signal out of the IN 1/ Out 1 path. If you remove Insert 1 on the H90, it removes the loop from Out3 to In 3 (where an external effect would be), and the signal becomes stereo only if H90’s Out 1&2 are connected.
2. Dual mode: only path 1 is available but it’s in stereo, which makes no difference to insert mode above.
In Dual mode, the H90 acts as two independent mono or stereo effects processors. There are two Paths that are independent of one another.
Path 1 uses 1/O 1&2 for stereo or just 1 for mono
Path 2 uses 1/O 3&4 for stereo or just 3 for mono.You may find this video valuable in understanding Dual routing mode: https://youtu.be/0G_WtfUatSc?si=jMzd5PxJjlTX-g_X
August 7, 2025 at 1:50 pm #191433
Maybe my article’s order confuses you, sorry about that.
Here is the first scenario:
Here are the second:
To make it short, I’m wondering:
If I use I/O 1&2 on H90 and put it in QC’s FX loop using insert mode (QC do support stereo FX loop), does it work? If it does, is it a stereo signal chain ? Which makes it work just like in dual mode with only path 1.
I know it’s not a usual way to use it, but I’m just curious about it.
August 7, 2025 at 4:51 pm #191436
If I use I/O 1&2 on H90 and put it in QC’s FX loop using insert mode (QC do support stereo FX loop), does it work? If it does, is it a stereo signal chain ? Which makes it work just like in dual mode with only path 1. I know it’s not a usual way to use it, but I’m just curious about it.
Yes, the H90 would function as a stereo effects processor in the QC FX Loop.
