Pitchfactor Stereo to mono
Home Forums Products Stompboxes Pitchfactor Stereo to mono
  • This topic has 5 replies, 3 voices, and was last updated 3 years ago by joecozzi
Viewing 5 reply threads
    • #170333
      manuelroland
        I’m using my PF in stereo with two amps. I really dig the stereo for most of the sounds I use but for specific sounds, I would like to be in mono. So I would like to have both amp playing the same.
        Is there a way to force a preset to be in Mono and let the others stereo ?
      • #170335
          Pretty sure the PitchFactor senses the physical cabling to determine mono or stereo.  Maybe something like the Boss LS-2.
        • #170337
          joecozzi
            This is not possible on a preset basis.
          • #170347
            manuelroland
              OK, too bad. Hope there will be an update. thank you
            • #170396
              manuelroland
                But in the Manual, page 51 there is this sentence
                “STEREO – this is the normal operating mode where both channels are Wet unless bypassed. It is here to allow you to return to normal stereo mode on a preset by preset basis. For example, in a two amplifier setup, you might want a shifter to come from one amp, but a reverb to feed both.”
                Thats exactly what I want to do. On one of my preset I want the effect to be on both amp. In this sentence, it looks like it is possible
              • #170397
                joecozzi
                  This part of the manual is taking about routing modes. If you set the PitchFactor’s routing mode to Wet/Dry, this means ONLY one side will get a mono version of the effect, but not both. You get to decide which side with Wet 1 (Out1 wet) and Wet 2 (Out 2 wet). The other side is always dry. If you set a preset to Stereo, the pedal operates like normal, not mono.
