Home › Forums › Products › Stompboxes › Pitchfactor & Device Manager
- This topic has 9 replies, 4 voices, and was last updated 1 year ago by
Eventide Staff.
February 16, 2023 at 8:16 am #169162
I have a pitchfactor for a few days.
I can connect it to the h9 control, but the device manager searches a device for a few seconds and then crashes. I wonder why?
February 16, 2023 at 9:00 am #169164
You will get an official response from Eventide staff, but I think they may want you to clarify whether you’re experiencing this only with the Eventide Device Manager, but not H9 Control. It would be helpful to specify what O/S your are using, too.
It sounds like you purchased a used device, so the firmware probably hasn’t been updated to the latest. I can tell you that I solved some puzzling PitchFactor issues myself in the past with the Eventide Direct Updater.
https://www.eventideaudio.com/downloads/?product=PitchFactor
February 16, 2023 at 9:29 am #169167
<p style=”text-align: left;”>- H9 control seams to work</p>
– software version: 5.2.0 (6)– pc laptop / windows 11
February 19, 2023 at 11:50 am #169269
Have now the Eventide Device Manager installed on an other PC (win 10).
It opens and does nor crash any more.
It recognizes Device Name, Version 5.2.0 (6) and serial number.
BUT just the Firmware Updates menu is available,
so I update, even it says 5.2.0 (6) is on the Pitchfactor.It seams to update and after about 8 or 9 minutes it says
“your device needs to be rebooted manually. after rebooting reselect your device.”
I do so but only to enter again in the Firmware Updates menu of de EDM…
I already updated (?) 4 or 5 times, but it´s a loop, I end always at the same place…
frustrating!
February 20, 2023 at 12:09 pm #169286
Sorry for the issues you are having. Please contact support@eventide.com and reference this post. We can provide some alternate troubleshooting and updating instructions there.
February 21, 2023 at 8:28 am #169297
So, conclusion:
it looks like you can only use the EDM for updating, nothing else… Too bad! But maybe the H9 Controll is optimal anyway?
Jerome Hyman commented:
I’m sorry, but EDM cannot be used for preset management with our Factor pedals. If you want a software editor for preset management, then you will need to use H9 Control. Make sure that you have V5 software installed or you will not be able to use H9 Control.
April 30, 2025 at 5:51 pm #189925
Same issue here on Win 11 with Tricerachorus.
I’ve tried multiple ports, restarted, launched as admin….. always crashes the same way if the pedal is connected. When not connected, it doesn’t crash.
April 30, 2025 at 6:11 pm #189926
Actually, it’s somehow related to the Windows user profile. I’ve tried my “clean” admin user account and it works there, it just crashes under my everyday user.
April 30, 2025 at 6:22 pm #189929
Ahh, nevermind…. it works in the H90 app, the Eventide Device Manager seems to be obsolete now.
May 1, 2025 at 9:14 am #189939
That is correct, for the dot9 stompboxes H90 Control has replaced EDM.
Other devices are still supported using EDM.
