Home › Forums › Products › Stompboxes › No output signal from outputs 3 and 4 on H90
- This topic has 7 replies, 3 voices, and was last updated 8 months, 3 weeks ago by
tiresias.
August 3, 2025 at 10:14 am #191358
I’m trying to leave input/output 3&4 set to line level for when i’m at home plugged into DAW etc. And use input output 1&2 set to instrument for gigging. This is to save me remembering to change line to intrument when I go out.
For some reason there is no output from 3 and 4. I’m getting input 3 / 4 okay but nothing coming out. The cabling is all okay.
Any ideas?
Cheers
August 3, 2025 at 10:24 am #191359
Are you using Dual routing mode?
August 3, 2025 at 10:39 pm #191370
Ah, could you say some more, I haven’t come across that? Are there adjustments that need to be made?
Cheers.
August 4, 2025 at 10:05 am #191378
From factory, the H90 runs in Insert mode, where I/O 3&4 are used for inserting external effects in the signal chain of the two Eventide algorithms. If you want to use the H90 like two independent mono or stereo effects processors, like you describe in your original post, then switch the H90 to Dual routing mode. I/O 1&2 will have its own path and 3&4 another. On a program basis you can store effects on either path depending if you’re at a gig (I/O 1&2) or at home (I/O 3&4). It would be possible to run I/O 1&2 at instrument level and I/O 3&4 at line level when connecting to your audio interface.
You would benefit from going deep into this topic by watching this video: https://youtu.be/0G_WtfUatSc?si=4YN7iveUwEtnjk5C
August 4, 2025 at 6:27 pm #191386
Thanks for staying with this. Does that mean I’ve got to save two copies of list to have different paths depending on gig or DAW?
August 5, 2025 at 12:14 pm #191401
That is correct.
My opinion is that it would be simpler to always use I/O 1-2 and go into your settings and switch from line level to instrument level when needed.
August 4, 2025 at 6:30 pm #191387
I just want to have a line-level input output of the same list from one stereo pair 1 / 2, and an instrument level from the other pair.
August 9, 2025 at 11:50 am #191450
thanks for confirming tbskoglund, that’s the conclusion I’d come to. The challenge is remembering to do so.
