Home › Forums › Products › Stompboxes › Need Help
- This topic has 6 replies, 2 voices, and was last updated 2 years, 11 months ago by
udi9.
May 29, 2023 at 12:29 pm #171607
i just bought an eventide micropitch delay and when it got home i kind a confuse how to put in in my pedalboard. How to working it as a stereo device and make it full use of it.
Can u guys gimme some tips and hints what i have to do. Ill share what i use in my old pedal board.
May 29, 2023 at 2:56 pm #171608
Looks like you’re not using amps?
I’d place the MP between the Timeline and Big Sky.
Start with the first preset (H3000 MicroPitch), turn the mix knob to 12:00 (it’s on 100% wet from the factory) and go from there.
The input of the MP is stereo, but you need an insert cable or a TRS to dual TS adapter to use it. Also set the switch on the back to Stereo.
Watch this video for more details:
May 29, 2023 at 2:58 pm #171609
This is the adapter I was referring to:
May 29, 2023 at 8:59 pm #171614
This is my pedalboard ampless rig, so im not using any amp. Boss ir200 act as an amp and cab. But it only have one input and output sent and return.
So i just need a trs cable??
And why between? Is it mod pedal have to be in before delay and reverb?? Or should i take out the timeline since MP has delay too??
May 30, 2023 at 2:35 am #171618
This is just my personal preference. I really like the tone of a stereo delay into the Micropitchshift sound, but you should experiment with the position of the MP in the chain and see what you like best. there are no rules here.
While the MP has a very nice delay, it is obviously not as versatile as the Timeline. if you need all the options the Timeline has to offer (analog, tape, looper, etc.) you might want to keep both.
If you want to use the stereo input of the MP, you’d need an insert cable or the adapter I mentioned earlier.
Watch the video I posted above, it shows in detail how to connect everything. -
May 30, 2023 at 11:20 am #171631
Oohh and one more, can i powered MP with cioks dc7?? Necause it says 9v 4,5W….its new to me for a pedal with this. Ussually it mAh…
Sorry for the stupod question, just dont wanna break the pedals
May 30, 2023 at 12:25 pm #171642
According to the spec sheet, the MP requires 9V DC @ 300mA.
I’m not familiar with the DC7, but if you have a 9V DC outlet that supplies at least 300mA you’ll be fine.
