Home › Forums › Products › Stompboxes › Muting Output 1 on H90
- This topic has 2 replies, 2 voices, and was last updated 1 year, 3 months ago by
CIW2025.
January 15, 2025 at 6:44 pm #187720
I’m setting up my H90 for a guitar rig with two external pedals as inserts. These two pedals use Return-in 3 & Return-out 3 and Return-in 4 & Return-out 4 respectively.
The signal chain is:
Electric Guitar one into Gig Rig Three2One
Electric Guitar two into Gig Rig Three2One
Acoustic Guitar into Gig Rig Three2One
Gig Rig Three2One > into H90 input 1 > Output 2 into front of Twin Reverb – this works great.
H90 Output 2 goes to a Mixing Desk PA
When I switch from electric to acoustic guitar (using the Gig Rig Three2One to select guitar inputs) is there a way to mute output 1 in the H90 so that the acoustic guitar signal only goes to the Mixing Desk PA and not the Twin Reverb?
The work around is that I put the Twin Reverb in standby but that means fiddling around the back of the amp between guitar changes…
Thanks.
January 15, 2025 at 7:17 pm #187722
Did you mean to say Output 1 goes to the Twin?
H90 Output 2 goes to a Mixing Desk PA When I switch from electric to acoustic guitar (using the Gig Rig Three2One to select guitar inputs) is there a way to mute output 1 in the H90 so that the acoustic guitar signal only goes to the Mixing Desk PA and not the Twin Reverb?
No, there isn’t a way to bypass Output 1 and Output 2 independently. You might need an external mute switch or volume pedal for the signal coming out of Output 1.
Just making sure: Are you using the Force Mono feature of the H90 found in the I/O section of the System menu? In this configuration it’s necessary because normally, if you connect to outputs 1&2 it makes the H90 function in stereo, not dual mono as it sounds you’re using it in your setup.
January 16, 2025 at 3:19 pm #187797
Hi Joe,
Thanks so much for your reply (and sorry for the signal chain SNAFU!) it means I can move on and find a workaround.
I have made the change to Force Mono too, thanks.
Cheers
Chris
