- This topic has 9 replies, 3 voices, and was last updated 2 years, 2 months ago by
Eventide Staff.
December 30, 2023 at 4:30 pm #176962
Although MOTU Digital Performer 11 can see the plugins in AU format in preferences, they are not listed in my Eventide folder when I right click in the insert of a channel in my project. My other Eventide products are in there. The 2 demos are authorised on my iLok2 USB. I’ve tried re-installing them and rebooting. I am using a Mac Mini (intel 2018) running OS X 13.6.
December 30, 2023 at 4:54 pm #176963
December 30, 2023 at 5:03 pm #176966
I judt tried installing the VST3 versions instead, set primary plugin to vst3 and the result is exactly the same. GRRR!!
January 2, 2024 at 10:17 am #177007
Hi, sorry for the delay on responding to this (we have all been out of office for the holidays) and thanks for your patience. Are you running a session that supports immersive channel layouts? Can you load any other higher channel count plugins on those tracks? It looks to me like you’re running a stereo session, and at present Blackhole Immersive and MicroPitch Immersive require an output format of LCR or higher.
January 30, 2024 at 10:02 am #177825
Hi, with the most recent update you can now load Eventide Immersive plug-ins on stereo tracks – are you able to view the most recent updates on your tracks now, in stereo? That would also confirm your original issue was a track format issue, and if you enable Spatial Audio formats you should be able to load Eventide Immersive plug-ins on those tracks and busses.
February 7, 2024 at 11:53 am #178019
By the time I got this reply, my demo/trial licence had already expired, so I was not able to test either plugin.
February 7, 2024 at 12:21 pm #178020
Hello, I’ve just extended your trial period for both plug-ins if you’d like to give them another shot. Let me know if you have any issues.
February 7, 2024 at 1:20 pm #178021
I downloaded them individually, restarted my Mac, Digital Performer 11.23 now sees them as mono and stereo plugins. I’m guessing DP11 is not compatible with some surround plugins, not that I would use them. Thanks.
February 7, 2024 at 1:33 pm #178023
p.s – I assume some controls are greyed out as they’re not available in the demo/trial of Micropitch Immersive. Is this normal?
February 7, 2024 at 2:16 pm #178024
Glad to hear that worked.
All of our demo licenses are fully featured, in MPI the Front/Rear and Top/Main parameters are greyed out because those are controls for output channels that are non existent when working in mono/stereo.
