- This topic has 7 replies, 1 voice, and was last updated 3 years, 8 months ago by
deepg.
October 7, 2019 at 9:35 pm #115549
Is it just me or is there a gate on signals lower than th 60db in the input of Equivocate?
It could be gating per band that is to save CPU or something. I just have to do a project with very low to very high volume changes.
There shouldn't be any gating on the EQ at all, it should pass signal at any level. There's a gate on the Match EQ functionality, where it won't try to match a signal that's too quiet, since in practice this just confuses the algorithm. Is this what you're talking about?
Thanks,
Dan
October 23, 2019 at 11:21 pm #153028
False alarm, had time to find the plug that was gating was FabFilter Pro Q2 with a high pass in linear phase mode very high.
If you want I can edit my heading of the original post.
Thanks for looking into it.
October 23, 2019 at 11:32 pm #153029
hold that one.. a few minutes back.. still testing
October 23, 2019 at 11:52 pm #153031
ok so I am supplying screen shots of the problem
here is the chain with MRecorder plugin capturing signals pre and post each instance of Equivocate.
and the level normalised results of the captures.
I am unsure why the mute/ gate occurs in the signal (see results marked in red)
Please note this chain produces no gating when the input signal is higher, ie increse gain before plugin chain.
October 23, 2019 at 11:56 pm #153032
BTW the pre normalised signal level post eq plugin 1 is -105db to -55db and the output of the second eq is similar but with the muted areas.
September 3, 2022 at 7:54 pm #165274
Culprit found!
Ableton Live mutes vst2 plugins when audio drops below -100dbfs.
Who knew right?
There is a fix (sort of) I’ll post here later the link but it involves creating or editing ‘options.txt’ and placing a time value that delays the muting of low signals BUT does not stop this behaviour altogether.
Took a few years to discover this. Sorry for thinking it was Equivocate.
September 3, 2022 at 11:30 pm #165275
