Home › Forums › Products › Stompboxes › H90 with OX box
- This topic has 5 replies, 2 voices, and was last updated 1 year, 9 months ago by
squidz66.
July 27, 2024 at 11:12 am #184039
Hi all, I’m wondering if someone may help me?
I’m wanting to use my compressor and drive before my H90 (so I can use drives etc.), then into my amp, then into my OX box, back into H90, out to s<span style=”font-size: inherit;”>tereo monitors.</span>
I feel like I’m missing something here. I want to come out in stereo.
I’m currently going in compressor pedal into in1
Out1 into amp
Ox out into input 3+4
Out 3 and 4 into monitors.
I’m so sorry for such a basic question..
But I can’t figure this out.
Can anyone help me?
I can’t seem to get this to work
Thanks
July 27, 2024 at 11:18 am #184040
Do I put the Ox as an insert?
July 27, 2024 at 12:19 pm #184042
Is there a way to go into h90, into my amp, out of amp?
July 27, 2024 at 12:22 pm #184043
I’m thinking the only way I can do it is, pedals in front. Stereo out…so I can’t have anything before
July 29, 2024 at 11:57 am #184058
The Ox Box should not be used as an insert as it needs to connect directly to your amp.
I would suggest using Dual Mode on the H90 and trying this:
Guitar > Compressor / Drive pedals > H90 Input 1
H90 Output 1 > Guitar amp input (amp connected to Ox Box)
Ox Box Outputs 1-2 > H90 Inputs 3-4
H90 Output 3-4 > Stereo monitors
This setup will allow you to have different effects before/after the preamp stage. Press the routing button to choose which preset is on which path: https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/edit-modes/routing.html#dual-routing
Let me know if you have any questions.
July 29, 2024 at 8:38 pm #184069
Thank you so much for the reply. I think I didn’t understand the insert/dual routing scenario. I’ll give thatxa crack. Thanks.
