Home › Forums › Products › Stompboxes › H90 Wha with external pedal expression with switch
- This topic has 3 replies, 2 voices, and was last updated 1 year, 9 months ago by
joecozzi
Eventide Staff.
July 23, 2024 at 5:22 am #183947
Hi, i need to use a Program with a Q-Wha algorithm in the A slot and a SpaceTime algorithm in the B slot.
But i’d like to use an external pedal to recall and control the wha. I have a mission engineering pedal with the switch and i’d like to use it to recall the program (with the switch) and immediately control the wha.
In this way i can recall this program from any program.
Also, i’d like to use the expression pedal like pedal volume in the other program (e.g. controlling the out gain of the program)
It is possible? How can i configure the h90?
I do this whit the kemper and it is super cool
I’ll appreciate any help
Thank you!!!!
Maurizio
July 23, 2024 at 10:47 am #183968
i’d like to use an external pedal to recall and control the wha. I have a mission engineering pedal with the switch and i’d like to use it to recall the program (with the switch) and immediately control the wha. In this way i can recall this program from any program.
Only MIDI controllers can recall a Program. Auxiliary switches like the one on the Mission Engineering expression pedal can be programmed to control active/bypass states but not to recall a specific program.
It’s important to note that if you want to use the switch on the SP-H9 and the expression pedal, you need to connect to the H90 with a TRS to Dual TS cable because the inputs can only be configured for an aux switch or expression, but not both. Check out this video: https://youtu.be/ZpfqKINai4w?t=140
Also, i’d like to use the expression pedal like pedal volume in the other program (e.g. controlling the out gain of the program) It is possible?
Yes, the expression pedal can be mapped to control output gain on a Program basis. Here’s how to assign any parameter to aux or expression pedals: https://youtu.be/5y14LwN9oAk?t=2888
July 23, 2024 at 10:59 am #183969
Thank you for your answer!!
In other post i read that you are considering to implement the auto engage of wha when the pedal is moved.
Kindly, i’d like to know if it has been done.
Thank you again!
Maurizio
July 24, 2024 at 5:23 pm #183995
This has not been implemented yet, but it is under consideration. No timeline at the moment.
