Home › Forums › Products › Stompboxes › h90: two mono inserts with stereo out
- This topic has 4 replies, 3 voices, and was last updated 1 year, 11 months ago by
Eventide Staff.
February 5, 2024 at 12:47 pm #177956
hi,
i’m planning a new pedalboard where the goal is to be able to insert h90 algos before my drive pedals, between the drive pedals and the dream ’65, and after the dream ’65 but before the source audio collider. i want to double check that the below signal path / routing scheme is viable before i get too far down the road:
[mono input path] guitar > h90 input one
[insert loop 1] h90 output 3 > drive pedals > h90 input 3
[insert loop 2] h90 output 4 > ua dream > h90 input 3
[stereo output path] h90 outputs 1 & 2 >> sa collider >> daw
your thoughts are much appreciated!
thanks,
tyler
February 5, 2024 at 1:50 pm #177958
Insert Loop 2 will need to return to H90 input 4, but that looks like it may be a typo.
Yes, this looks fine. You will have 2 mono insert paths; 1 for your drive pedals and 1 your UA Dream. These can move around in the H90’s signal path by adjusting the insert routing. Then, the H90 will output stereo to the SA Collider, and that will output stereo to your DAW.
February 5, 2024 at 2:05 pm #177959
yes, typo. thanks for confirming!just pulled the trigger on the remaining pieces so looking forward to wiring this up and reporting back
June 5, 2024 at 10:52 pm #183062
Would an algorithm after the inserts in this setup be true stereo? E.g. a ping pong delay?
June 6, 2024 at 9:22 am #183064
Yes, when the output mode is auto (which is the default setting) the H90 will automatically sum to mono, or mult to stereo when necessary to handle the mono inserts correctly. If the outputs of your H90 are connected in stereo, and you put and algorithm as the last block in your routing chain, that effect will be in stereo. On the other hand, if you have a mono insert as the last block in your chain, the H90 will output a dual mono signal. More information about the routing behavior can be found here: https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/system-menu/io.html
