H90 Stereo Processing
Home Forums Products Stompboxes H90 Stereo Processing
  • This topic has 8 replies, 3 voices, and was last updated 3 years ago by joecozzi
Viewing 5 reply threads
    • #170582
      crjohnston77
        I’m having an issue where the H() is not maintaining a stereo image from preset A to B in series.
        I’m running the H90 in Dual Routing Pre/Post mode, with a guitar preamp/cab sim, into a stereo pair of mixer line inputs.  Input/Outputs are as follows:
        In 1 – Guitar
        In 3 – Preamp Out
        Out 1 –  Preamp In
        Out 3/4 – Mixer Stereo Line In
        When running this way, with Preset A in series with preset B on Path 2, preset B is only taking the left side information from preset A, and collapsing it to mono before processing it.
        I have noticed that if I run a stereo output from my preamp to In 3 and 4, that the problem goes away; the stereo information is retained.  This is a problem, as not all of my preamps have stereo pairs of outputs.  I should be able to send a mono signal into path 2, have A split to stereo, and have B process that stereo information in series.
        Please let me know if there is any other info I can provide, or if I am simply in error.
        Thanks for any assistance you can provide.
      • #170583
        joecozzi
          What version of the H90 Software are you running? Go into System settings > Global > About
          • #170610
            crjohnston77
              I will update to 1.4.3, and see it is resolved.  Thanks Joe!
          • #170590
            jlane0710
              https://www.eventideaudio.com/forums/topic/dual-mode-mono-pre-stereo-post-question/
              This sounds similar to the issue I reported at the end of the thread above.  See the last two posts in the thread.
            • #170591
              joecozzi
                Software 1.4.3 fixed this issue. Are you still having problems?
                • #170611
                  crjohnston77
                    I don’t see where 1.4.3 is available.  1.3.0 is listed as the most recent available download.
                  • #170626
                    jlane0710
                      I can’t check this now, but if you connect to the H90 pedal with the H90 control app, it will probably ask if you want to update.
                  • #170592
                    jlane0710
                      I didn’t realize there was an update.  The sticky thread still says 1.3.0.  I will update and check it out when I get a chance.
                    • #170627
                      joecozzi
                        I jumped the gun. The bad news is the update is not available yet. The good news is the fix is coming in the next update which should be out very soon, probably first week of May. It will bring along with it the new algorithm announced at NAMM.
