Home › Forums › Products › Stompboxes › H90 Spring Algorithm Midi CC Issue
- This topic has 10 replies, 2 voices, and was last updated 1 year, 10 months ago by
udi9.
June 30, 2024 at 4:47 pm #183530
i have two presets with spring reverb:
Preset 1: spring with trem intensity set to 0, (I don’t want tremolo in this preset)
Preset 2 : sending a midi CC with Morningstar MC6 PRO for activate the tremolo intensity(from 0 to 50)
the tremolo does not activate, it is activated only if I move the value manually from 50 to 49 for example or any other value.
Thanks
July 1, 2024 at 6:23 am #183534
Make sure your H90 and MC6 are on the same MIDI channel, and try a different CC#. some devices might not recognize CC#0.
Also, make sure the MC6 is sending the CC message at 127.
July 1, 2024 at 6:41 am #183535
One more thing just to make sure, I don’t know if by the “2 presets” you mean two MC6 presets or two H90 presets….but if we’re talking about the H90, you don’t need a separate preset to change a specific control, you can do it within the same preset. Just send the CC you chose to the H90 and the programmed control will change.
July 1, 2024 at 6:47 am #183536
My H90 and MC6 are on the same midi channel and the value of Midi CC is 127.
I also tried with another midi cc but with the same result..
thank you so much for your reply
July 1, 2024 at 6:52 am #183537
2 Presets in the MC6 and the same preset for H90:
MC6 preset 1 to H90 preset 1 with no tremolo
MC6 preset 2 to H90 preset 1 but with midi cc for activate tremolo
July 1, 2024 at 6:55 am #183538
I just tried it here and it’s working fine. Maybe your MC6 is also sending a PC message on preset 2? make sure you’re only sending the CC message.
July 1, 2024 at 7:07 am #183539
Here’s one more thought, if you want to send a Program Change message with the CC message, you might need to add a short delay between them for the H90 to recognize both messages. I’m not completely familiar with the MC6, but if you can’t program a delay between the messages, try to send the PC on press and the CC on release.
July 1, 2024 at 11:52 am #183544
H90 recognizes the message because the value in the trem intensity change but there is no tremolo in the audio..
July 1, 2024 at 12:57 pm #183545
Oh, I see. I thought the value isn’t even changing….
I don’t have a MIDI controller that can send PC messages right now, but I’ve tried sending a CC message to the Intensity control in the Spring algo and it works as expected.
What happens when you send just the CC message and your first preset is already loaded? -
July 1, 2024 at 1:04 pm #183546
if I only send a Midi CC it work..
July 1, 2024 at 2:11 pm #183547
Maybe someone from Eventide will comment soon, but in the meantime I’d try my suggestion above – set the MC6 to send the PC message on button press and the CC on button release, see if that works.
