Home › Forums › Products › Stompboxes › H90 Questions (lists and presets)
- This topic has 2 replies, 2 voices, and was last updated 2 years, 11 months ago by
udi9.
May 17, 2023 at 6:57 pm #171318
1. Is there an option on the H90 to limit the number of programs in a list?
I’ve created a user list with 9 programs and I want to scroll through them in a loop – after reaching program 9 I want to go back to program 1 without the need to scroll back through the entire list.
2. Is there a way to rename presets in the H90 Control app? I can see an option to rename lists and also programs, but couldn’t find a way to rename presets.
3. Are there any plans to bring the dot9s factory presets to the H90?
<p style=”text-align: right;”></p>
Thanks! -
May 17, 2023 at 7:48 pm #171320
No.
If you’re using Bank mode, holding down the P footswitch will take you back to Bank 1. You can then load Program 1. Only other quick option is using a MIDI controller to go back to Program 1 instantly.
If you’re in the Edit window, you can click on the 3 vertical dots next to the preset name. Clicking ‘save to library’ will allow you to rename it. Just keep in mind it creates a new preset in the library, so the old one will still exist. You can then go into the Preset Library and delete the old one if you want to.
No, there are no plans to port all those presets over, but there is some crossover as H9 presets are in the H90. Some of those are also dot9 presets.
May 18, 2023 at 1:21 am #171324
Thank you, Joe!
Please consider adding an option to delete (not just initialize) unused programs from a list and also an option to rename presets to make the workflow a bit quicker.
Cheers
