Home › Forums › Products › Stompboxes › H90 Power draw & routing
- This topic has 107 replies, 38 voices, and was last updated 7 months, 1 week ago by
jononotbono.
November 15, 2022 at 7:30 pm #166740
Hi all, just ordered y H90, thanks again Eventide for the continued evolution of the product line ! Couple of questions: what’s the power draw in milliamps for power brick integration ? Are the routing combinations (in/out/stereo/dual mono) configurable on a per preset basis ?
thanks
November 15, 2022 at 7:40 pm #166743
Should add – I mean the I/O config routing (not the internal signal path)
November 15, 2022 at 9:30 pm #166749
What’s the power draw in milliamps for power brick integration?
Although we provide a 12V 1 amp power adapter, the H90 can be powered with 600mA. Testing with our own PowerMax/Mini products we can safely run it at 12V 500mA because of the excellent efficiency of those power supplies. 9V works as well, but it’s a hungry 800mA.
Are the routing combinations (in/out/stereo/dual mono) configurable on a per preset basis ? thanks
The H90 has two global routing modes – Dual mode and Insert Mode. When you designate one, the program routing (series-parallel, insert positions [insert mode only]) can change on a program basis. Keep in mind, however, that Programs designed in Insert Mode do not work in Dual mode and Vice versa.
November 16, 2022 at 7:13 pm #166763
I have a power brick (Voodoo Power 3 Plus). Would combining two 9V 500mA outputs with a current adapter to get 9V 1000mA work OK?
January 3, 2023 at 8:05 am #168149
If you’re using a pedal Power 3 Plus, simply use one of the 12V 1A outputs on the far left side of the power supply. This is more than enough juice and the optimal voltage.
March 4, 2023 at 9:36 am #169547
does the power mini come with a cable that will go straight into the h90? if so I’m going to buy one straight away!
March 5, 2023 at 12:25 am #169564
Yes.
November 16, 2022 at 9:44 pm #166765
Yes. Voodoo makes the Current Doubler adapter.
January 27, 2023 at 9:31 pm #168706
I’m using a Voodoo Lab pedal power 2, will it be able to power the Eventide H90 even considering that it is reverse polarity. If so what barrel connector will I need to purchase to accomodate the H90.
January 30, 2023 at 11:52 am #168747
One the Pedal Power 2 Plus, use outputs 5 and 6 to double the available current. Set switches 5 and 6 both away from NORMAL and use a current doubler adapter with the red 5.5 x 2.5mm center-positive barrel cable.
Current doubler: https://voodoolab.com/product/current-doubler-adapter/
Reverse polarity cable: https://voodoolab.com/product-category/cables/reverse2-5/
November 16, 2022 at 10:46 pm #166767
Thank you!
November 17, 2022 at 10:12 am #166781
And what about ciocks DC7?
it provides max 12v 500ma
is a double cable needed in this case too?
thanks-
November 17, 2022 at 11:26 am #166783
A single 12V 500mA outlet from a DC7 will power the H90.
November 17, 2022 at 5:33 pm #166800
But *not* the 12V 400mA outlet from the original PowerFactor? That’s what I’m using now, and it *seems* to be working properly, but I’m starting to get a little paranoid about it.
November 17, 2022 at 6:56 pm #166803
Hi all, and Eventide gurus ! The complexities of electricity !
Just to confirm (as im a bit nervous about hitting the unit with 18v) – 2@ 9 volt, 400ma outputs combined with the Voodoo Lab current doubler https://voodoolab.com/product/current-doubler-adapter/ will work with the H90 and not damage the unit ?
I am using the following https://www.sweetwater.com/store/detail/PedalPwrDig–voodoo-lab-pedal-power-digital-4-output-isolated-guitar-pedal-power-supply
Utilising the two 9 volt 400ma outputs as described above. Thanks !
November 17, 2022 at 7:01 pm #166804
We do not recommend under powering the unit with only 400mA.
November 17, 2022 at 7:02 pm #166805
Just to confirm (as im a bit nervous about hitting the unit with 18v) – 2@ 9 volt, 400ma outputs combined with the Voodoo Lab current doubler https://voodoolab.com/product/current-doubler-adapter/ will work with the H90 and not damage the unit ? I am using the following https://www.sweetwater.com/store/detail/PedalPwrDig–voodoo-lab-pedal-power-digital-4-output-isolated-guitar-pedal-power-supply Utilising the two 9 volt 400ma outputs as described above. Thanks !
You will be alright.
November 17, 2022 at 7:07 pm #166806
By the way, this cable s doubles the current not the voltage, so you’re not hitting it with 18v.
November 17, 2022 at 7:09 pm #166807
Thankyou joecozzi – fed ex mentioned my unit is somewhere south of Hawaii over the pacific. Hopefully it will get to Australia (without a stop over at the Marshall Islands) 😀
November 17, 2022 at 9:09 pm #166819
I have a cioks dc5 if I use the CIOKS 4022 Type 4 Stack Flex Power in the outs that have 300ma each would that be enough to power the H90? Two 12v at 400 ma each.
thanks
November 17, 2022 at 11:24 pm #166824
I have a cioks dc5 if I use the CIOKS 4022 Type 4 Stack Flex Power in the outs that have 300ma each would that be enough to power the H90? Two 12v at 400 ma each. thanks
No. The stack flex cable is used to add the voltages of each outlet. The H90 cannot accept 18V or 24V.
November 18, 2022 at 6:58 am #166826
Ok thanks. Is it the cioks 8800 that doubles the ma? So if I used two 12v 300ma outlets with cioks 8800 will that then provide it 12v 600ma and would that be safe?
thanks again
November 18, 2022 at 7:03 am #166827
Yes and yes.
November 22, 2022 at 10:56 pm #166989
Hey there. Looking forward to receiving my unit soon. I am currently running power to m H9 with current doubler cable from my Voodoo Labs pedal power two from the two “Line6” outlets. Will this work for the H90 as well?
November 22, 2022 at 11:12 pm #166990
If the dip switch is ON for 12V functionality and you use a current doubling cable, you’ll achieve the minimum amount of power to turn the unit on. So, the answer to will it work is yes. However, at boot up, the H90 spikes to about 550mA. I am not familiar with that power supplies ability to handle that since this method would only top out at 500mA. I would search elsewhere.
November 28, 2022 at 6:10 pm #167196
I just confirmed with True Tone that their CS7 will power the H90. Even though the highest current output is listed as 500ma, the total current load can be up to 1900ma which is automatically distributed as needed, as long as the total draw doesn’t exceed that total current number. Given that my other pedals draw about 200ma, I have a fair amount of headroom.
November 28, 2022 at 10:37 pm #167197
Hi
I have a JUMA pedal power from stymon and it has 12V 500mA output option. Do I still have to use current doubling cable for the enough amount of current?
November 28, 2022 at 10:45 pm #167198
I’ve just found that JUMA 12V provides 350mA not 500mA, so I would need use current doubling cable.
December 11, 2022 at 3:58 pm #167579
I tried this today, It powered up, but a very loud hum.
Does anyone have any idea what the hum is from?
Works great with no hum with the wall wart it came with.
December 11, 2022 at 4:29 pm #167581
If you’re using one 9V 500mA outlet, my guess is that you’re under powering the H90. You need a current doubler cable and combine the 500mA outlets.
December 11, 2022 at 7:26 pm #167584
I have no idea where the hum is coming from (maybe a grounding issue with another pedal?). I used my CS7 to power an H90 with 3 other pedals and it worked perfectly. Make sure you are using the polarity reversal adapter.
December 12, 2022 at 7:41 am #167592
i have the CL6 cable plus should not be a ground issue if the wall wart works just fine.
i will grab a current doubler and see what happens thanks
December 12, 2022 at 9:05 am #167594
has anyone else tried this and can report? really don’t want to have to buy a new pedal power supply to power the h90 🙂
December 12, 2022 at 9:46 am #167599
Specs wise, this should work as long as you switch the outlet to 12V. According to the manual, using a current doubler cable should give you 500mA (12V 250+250). I know the H90 has a startup spike of around 565mA. I don’t know whether the Pedal Power 2 Plus has the capability of reinforcing current where it’s needed for this spike like other manufacturers. May want to ask their support. This is the reason Eventide recommends 12V 600mA.
December 12, 2022 at 4:16 pm #167608
Noob question for the people powering the H90 with power supplies – Are you all using reverse polarity adapters ? I’m under the impression that the H90 is center positive, and most power supplies are center negative.
December 15, 2022 at 7:52 pm #167751
<p style=”text-align: left;”>Hey Joe, I rebuilding my board to accommodate the H90 and have a DC7. I intend to run this at 12V which should supply 500mA, which you stared should be adequate. I also see you mentioned if you’re using a Cioks you don’t need a polarity reversing power cable? What’s the reasoning there? I have one of their red tipped cables which I thought was for that purpose. Thanks!</p>
December 15, 2022 at 9:29 pm #167753
I intend to run this at 12V which should supply 500mA, which you shared should be adequate.
Correct, this was confirmed by Cioks.
The green Cioks cable, the Flex type 4, already incorporates a center-positive connector that is 2.5mm.
The red cable, or the Flex type 2 cable, is also center-positive but it is 2.1 mm connector not suitable for the any Eventide pedal.
December 30, 2022 at 12:04 pm #168063
I can confirm my Cioks DC7 at 12v with included green cable works great with H90.
February 4, 2025 at 1:46 pm #188008
Hi, I have Cioks DC7. I set it to 12V 500mA. When I power the H90 I hear clicks :(. That happened when I tried to power my HX stomp. The sound went away as soon as i got a doubler cable for it.
February 4, 2025 at 3:37 pm #188016
Sorry, I’m not sure what this issue is. Are you sure the setting is correct? 12V at 500mA should work fine.
Please send a video of the issue to support@eventideaudio.com.
December 30, 2022 at 12:47 pm #168066
Kevo888 are you using 2 , 12v outlets to power it , or just 1 @500ma ?
December 30, 2022 at 7:39 pm #168068
Just one at 12v.
January 2, 2023 at 6:48 pm #168133
I’m still pretty confused with this whole power draw thing. I understand I will probably need a current doubler cable for my Stryman Zuma https://www.sweetwater.com/store/detail/PPAP–voodoo-lab-current-doubler-adapter-4-inch-str-str-y-doubler
And I need a reverse polarity cable to hook into the H90. Here’s the confusing part, at least for me. Sweetwater sent me this link for the reverse polarity cable. https://www.sweetwater.com/store/detail/DCRR2.5RP18–vertex-effects-2.1mm-2.5mm-angle-angle-reverse-polarity-dc-cable-18-inch
And Stryman sent me this link for the cable I would need. https://www.strymon.net/product/polarity-reversal-cable-2-5mm/
My rep from Sweetwater said that cable from Stryman wouldn’t work and the rep from Stryman said that people with H90’s are using it. Seems like 2 entirely different cables. Can anyone point me to exactly what I need to hook the H90 up to my Stryman Zuma? Thanks!
January 2, 2023 at 7:11 pm #168134
Sorry I forgot to put the correct links in to my last message. I guess there’s no way to edit comments after you make them.
January 2, 2023 at 7:21 pm #168135
Hi philh0954,
Strymon doesn’t sell a current doubler cable, so I would go with the Voodoo Lab/Vertex combination of products. Together they will allow you to power the H90 from your Zuma. The problem with the Strymon adapter is that it’s female on one side, so it would only work for a pedal that only needs the power from ONE outlet and in conjunction with one of their barrel cables. That’s not the case with the H90. Hope that clarifies things for you.
January 2, 2023 at 7:43 pm #168137
Thanks for the clarification. I’m still thrown of a little bit from the email Stryman sent me. Here the text of it:
“We have never used the cable that you’ve just linked, however, we’ve had customers use our polarity reversal cable with a current doubler for Eventide products for years with no issues whatsoever.
The current and polarity adapters that we sell still require the standard DC power cable that Zuma/Ojai comes with in order to connect it all. It appears that the Sweetwater rep may not understand this.
I hope this clears it up for you!”What you are saying I believe is that all I need to power the H90 with my Zuma is the current doubler cable and the Vertex reverse polarity cable that Sweetwater linked to. I will not need the cable that comes with the Stryman, right?
January 2, 2023 at 8:04 pm #168138
I’m still thrown of a little bit from the email Stryman sent me. Here the text of it: “We have never used the cable that you’ve just linked, however, we’ve had customers use our polarity reversal cable with a current doubler for Eventide products for years with no issues whatsoever.The current and polarity adapters that we sell still require the standard DC power cable that Zuma/Ojai comes with in order to connect it all.
I do not see a current doubler adapter on their website, so we’re both confused.
Correct.
January 2, 2023 at 8:12 pm #168139
They had told me they don’t sell the current doubler.
Here’s another email I just got from them:Victoria Godfrey (Strymon)
Jan 2, 2023, 15:53 AKST
Hi Phil,
Attached is a screenshot from Eventide’s website stating that the H90 is positive polarity.
We do not sell current doublers, as previously mentioned. You could use this current doubler:
Which would connect to the DC power cables that come with Zuma, which then would connect to our red-tipped polarity reversal cable:
https://www.strymon.net/product/polarity-reversal-cable-2-5mm/Which would then connect into the H90.
I hope this clears it up for you.
January 2, 2023 at 8:20 pm #168140
What they’re forgetting to tell you is that with Strymon’s adapter you would have to use one of their barrel cables in between. Two adapters with female connectors alone can’t be joined.
January 2, 2023 at 8:28 pm #168141
So you’re saying that I could do it with their reverse polarity cable but would need to use their barrel cables as well. Basically with their way I’d need 3 cables attached together and Sweetwaters way would only be 2 cables, right?
January 2, 2023 at 8:29 pm #168142
Correct.
January 24, 2023 at 2:48 pm #168627
I have two available ports on a “Pedal Power Digital” supply. Each port is 9V 400ma. If I use the Voodoo Labs current doubler adapter, will the H90 receive sufficient and “healthy” power?
January 24, 2023 at 2:51 pm #168628
Yes
January 24, 2023 at 10:07 pm #168634
One more annoying question (first Nasa pedal of this type I have ever had). I see normal power cable connectors are too small to fit the male power connection on the H90. I have a current-doubler cable ready to, so what pedal power cable will fit properly on the H90’s power connector coming from the end of the current doubler cable?
January 24, 2023 at 10:10 pm #168635
2.5mm center positive connector. Like this one: https://voodoolab.com/product-category/cables/reverse2-5/
January 25, 2023 at 12:58 pm #168652
Please make sure that you are delivering the correct polarity. I use a TrueTone power supply and I had to get an adapter that went from center negative to center positive.
March 3, 2023 at 7:41 pm #169530
Sounds like i could use a single 12v output from a Strymon Ohai r30?
March 3, 2023 at 11:14 pm #169534
No, That’s not enough power as the 12V outlet of the Ojai R30 only puts out 375mA. You could use either two 9V outlets with a current doubling cable and a polarity converter cable with a 2.5mm barrel on the H90 side, or you can use two 12V outlets with the same cables.
March 4, 2023 at 3:40 pm #169561
Oh, actually the current drops to somewhere around 360ma or so when selecting 12v on the ohai so I guess I’ll need a current doubler
April 30, 2023 at 7:30 am #170743
I got my H90 and the inclosed power supply is 12v 1A. I have the the Eventide PowerFactor v1.2 that will only do 12v 400mA. How can I use this power supply or do I need to do something else.
April 30, 2023 at 9:28 am #170745
If it’s the PowerFactor 2 then you’ll need to combine outputs 7 & 8 using a current doubler cable (8800 Parallel Flex) into a green Flex cable to power the H90 properly.
April 30, 2023 at 4:29 pm #170749
It doesn’t say PowerFactor 2, just PowerFactor but it has the following and it appears that that will work. So 12V 800mA is good?
Outlet 5-6: 9 or 12 V DC / 400mA
Outlet 7-8: 9 or 12 V DC / 400mA
Outlet 9-10: 9 or 12 V DC / 400mA
I don’t know if you can answer this and it’s not related to the H90 but is there a way to combine two 9V outlets to get 18V plus double the amps?
April 30, 2023 at 4:49 pm #170751
Yes, you’ll have to combine two of the 12V 400ma outlets with a parallel current doubling cable.
Yes. For this you need a Voltage Doubling cable. 2200 Series Adapter cable. By using two isolated outlets the Series adapter Flex gives you the sum of voltages of the two outlets used. This adapter Flex cable should be used in combination with any of Eventide/CIOKS standard Flex cables if you want to power an 18V, 24V, or even a 40V pedal.
DO NOT USE THIS FOR THE H90!
May 31, 2023 at 10:47 am #171653
VL Pedal Power 3 Plus user here. Is there not simply a single cable that will connect the PP3P to the H90?
Would this one work, attached to the 12v 500mA outlet?.. https://voodoolab.com/product-category/cables/reverse2-5/
May 31, 2023 at 12:01 pm #171656
VL Pedal Power 3 Plus user here. Is there not simply a single cable that will connect the PP3P to the H90? Would this one work, attached to the 12v 500mA outlet?.. https://voodoolab.com/product-category/cables/reverse2-5/
I’m also using the Pedal Power 3 and asked Voodoolab about it. They suggested to use one of the 12V X-Link (1A) outputs with a reverse polarity 2.1mm/2.5mm cable. Works like a charm!
This is the cable you need:
May 31, 2023 at 3:11 pm #171659
I did wonder if I could use one of these outputs, but was paranoid I’d screw up my lovely new pedal. That’s perfect as I have that cable already. Thanks!
August 1, 2023 at 6:02 pm #172849
Hello Eventide Team
I have a strymon Ojay R30. In this unit, it have 2 switchable outlets (9 V DC @ 500 mA, 12 V DC @ 375 mA & 18 V DC @ 250 mA)
Could i use voodoo PPL6-R and Current Doubler Adapter PPAP?How can i power up my H90 with it?
Greetings from Brazil!
August 11, 2023 at 9:03 am #173071
Yes, this the correct configuration of cables. Sorry we didn’t see this message sooner.
August 11, 2023 at 4:18 am #173068
Hi team!
Recently got my h90 and loving it but I would like to add the pedal to my current daisy-chain powerunit with plenty of juice at 9v, barrel plugs of 2.1 mm and center negative. What adapter/do you suggest I buy? I’m located in Europe/Holland. Would one of these work? Otherwise – what do you suggest?
https://www.bax-shop.co.uk/guitar-effects-power-cables/strymon-polarity-reverse-cable-2-5-mm-2-1-mm-straight-15-cm?q=eventide%20polarity
https://www.bax-shop.co.uk/guitar-effects-power-supply/truetone-cl6-l6-converter#informationThanks!
August 11, 2023 at 9:08 am #173072
These adapters will do the job provided the power outlet puts out 800mA @ 9V or 600mA @ 12V. Otherwise, you will need to combine more than one outlet with a current doubler cable.
August 15, 2023 at 11:20 pm #173187
Hi all,
I confirm that powering up the H90 with Voodoo Lab Pedal power 2+ (outputs 5 & 6 w/ dipswitch in the up position) works just right so far.
I built myself a custom current doubler + polarity inverter connector, but you can use the adapters sold by Voodoo Lab.
Hope it helps!
November 25, 2023 at 3:08 pm #176114
Can I use the Pigtronix power supply to power the H90 by combing two 12v 300ma slots?
November 25, 2023 at 3:37 pm #176115
Yes, as long as you use a current doubling cable, not a voltage doubler. Keep in mind the input to the H90 is reverse polarity (center-positive) and 2.5 mm.
November 25, 2023 at 4:08 pm #176116
Thanks. I’m assuming a current doubling cable is easy to find?
What are the two best power bricks you recommend?
Does the smaller version of the Eventide Cioks power the H90?
November 25, 2023 at 10:57 pm #176127
Hi Jazznan,
I usually recommend the combination of these two cables:
https://voodoolab.com/product/current-doubler-adapter/My personal favorite power bricks or power supplies for pedals for higher power requirements would be the Eventide PowerMax, PowerMini, or Cioks DC7, or from another brand, the Strymon Zuma.
Yes, the smaller PowerMini can provide enough power from one outlet run at 12V.
November 25, 2023 at 6:41 pm #176118
I love the True Tone One Spot CS12. It handles an H90 and a bunch of other boxes with ease. It also automatically assigns current where needed, so no current doubling cables needed. It can provide a total of 3000ma of current, which should be enough for a lot of pedals.
November 25, 2023 at 7:50 pm #176122
Thanks! Could explain to me how Mmmm which port you would connect the H90 to? Thanks (I’m a total newbie)
November 28, 2023 at 8:27 am #176223
I have a power supply that has 10 isolated outputs, but only one is 12v 300ma… according to what I read here, it’s not enough for powering the h90… therefore I need the double current cable…
but here is my doubt:
The power supply has 3 outputs of 9v 300mA and only one of 9v 500 mA.
To reach the 9v 800ma required by the h90 I will have to combine the output of 500ma + one of 300ma… Would there be any problem with combining these different outputs??Thanks.
The h90 is amazing!
November 28, 2023 at 8:30 am #176224
No problem at all.
February 18, 2024 at 4:52 am #178326
Can I safely run 4x H90s on an Eventide Powermax by Cioks power supply?
Would there be any issues with the startup current mentioned? In theory could you safely run 7?-
February 18, 2024 at 4:03 pm #178345
4 H90’s at 12V, Yes. 4 at 12V and two coupled 9V outlets for a fifth unit, yes.
February 18, 2024 at 3:40 pm #178343
Can I safely run 4x H90s on an Eventide Powermax by Cioks power supply? Would there be any issues with the startup current mentioned? In theory could you safely run 7?
Must be quite a rig with 4 H90s!
I don’t know if the Eventide Powermax will provide enough current. It appears that at 12 volts, it provides 500ma for each output, instead of the suggested 600ma. I use the True Tone One Spot CS12 and it can handle up to 3000ma which is automatically distributed across all available outputs and has 4 12v outputs.
I have one and it’s been flawless.
The Powermax may work if you start up each H90 separately, but that’s a wild guess.
February 18, 2024 at 5:10 pm #178346
Well I’m just spitballing. It’s not a massive rig at all. It’s really just a massively pimped Analog Rytm and some synths. Im definitely going to have 3 so it sounds like it should be worry free with the powermax. I’ll add the true tone to my reading list though.
February 18, 2024 at 5:26 pm #178348
Well, Joe is the man, so either would work.
April 18, 2024 at 4:29 pm #181126
is there any sonic or physical benefit to running 12v 1a vs 12v 500ma?
April 19, 2024 at 9:35 am #181134
No. Note that we only officially recommend using an Eventide or Cioks equivalent power supply when using 12v 500ma as we have tested those specific power supplies.
April 25, 2024 at 2:48 pm #181413
Hello there. At the moment I’m powering up underneath my pedalboard with the original power supply connected directly to my Furmann conditioner. All other pedals are connected to two different power bricks. I’m all nervous about it too, like many here, of using the bricks for my H90. So, that being said, One of my bricks is the “Palmer PWT 12 MK2” (love the unit) I did not try it with it yet. This unit has a bunch of 9v 300 mA and four 500mA in which you can choose 9,12,18 or 24 v. Would be safe for the H90 if using two of the 500mA at 9V to power it up? or better another combination. That way I could use the bricks and put the original power supply out of the board. Thxs in advance.
You must be logged in to view attached files.-
April 25, 2024 at 2:57 pm #181416
Yes, 2 9V outlets at 500mA would work with a parallel adapter, such as this: https://store.eventideaudio.com/collections/cables/products/8800-parallel-adapter-flex-10cm-sand-grey
July 25, 2024 at 7:39 am #184000
Are there benefits to running the H90 using a 12v supply over a 9v? Headroom, processing speeds, or any other useful or operational benefits?
July 25, 2024 at 9:23 am #184001
There will be no difference in how the pedal operates. They are just different options to power the pedal depending on what power supply you have etc.
May 31, 2025 at 2:23 pm #190427
Hi;
I’m gathering backup supplies for my system and I am wondering about the H90’s voltage regulation. Can I run it from a 15v 1A supply? This would let me share a single backup (not simultaneously) with my Radial Key Largo.
TIA
May 31, 2025 at 3:25 pm #190428
No. 12V or 9V only.
June 7, 2025 at 9:59 pm #190525
I have an H90. I have two spots left on my Fender Engine Room power supply- one is 9v500mA, the other is switchable so I can also get 12v375mA. Can I combine 9v500mA with 12v375mA, or would it be better to combine 9v500mA with 9v500mA? Does the pedal sound better at 12v than it does at 9v?
June 9, 2025 at 9:20 am #190534
No, you should not combine two different voltages together. Yes, combining two 9v 500mA outlets is the best option.
No, it makes no difference sonically with a digital pedal.
June 9, 2025 at 2:15 pm #190544
Thanks for the quick response, that’s good information.
June 12, 2025 at 8:36 pm #190617
Well I’m going crazy here. I cannot find a combination of currently available cables or adapters to power the H90. I have a Fender Engine Room. I have available 2 9v500mA outputs (2.1mm). So I need a current doubler cable. Then I need to convert that to a 2.5mm plug. And also switch the polarity to center positive. So I need three cables with the correct female/male plugs. In what order?
There is a Gator cable that does two things- doubles the current and ends in a 2.5mm male plug, but it’s still center negative.
why why why why why why why why why
June 12, 2025 at 8:42 pm #190618
These two cables work together:
https://voodoolab.com/product-category/cables/curent-doublers/
June 12, 2025 at 9:49 pm #190619
Thank you!
June 22, 2025 at 2:54 am #190685
I have a Voodoo Lab Power Pedal Plus 3, I’ve seen that they say you can connect one of the 12v 1A outputs on the left side of the power supply to the H90, but do I need a polarity adapter?
June 23, 2025 at 10:48 am #190695
Yes. Either an adapter or an already made cable like this: https://voodoolab.com/product-category/cables/reverse2-5/
September 19, 2025 at 3:05 pm #192088
Sorry If I have misread anything here but I have a Voodoo Labs Pedal Power Plus 3 and is it possible to use it to power the H90? Would love to stop using the adapter that comes with the H90.
I’m using all 12 DC power outputs already but I’m curious about the 12V 1A two outputs on the far left of the Voodoo Labs?
Please someone make my Friday night 😂
September 19, 2025 at 3:46 pm #192091
It looks like the comment directly above this post is the same question, but I’m not familiar with this power supply and the manual doesn’t provide much info.
I’d suggest contacting Voodoo labs and see if they recommend using one of those ports to power a single device. The manual states these ports are for powering expanders, but they may work fine.
September 19, 2025 at 4:23 pm #192098
haha! Sorry I totally didn’t even see that. Yes, same question!
September 19, 2025 at 4:34 pm #192100
Just been doing a big of digging and those 12v 1A power outputs are not for powering pedals. They are for powering Voodoolabs Expansion units and then using an expansion units, you can power the H90. Guess I’m buying an expansion unit then 😂
