Home › Forums › Products › Stompboxes › H90 Playlist After Reboot Changes
- This topic has 8 replies, 4 voices, and was last updated 10 months, 4 weeks ago by
Eventide Staff.
January 27, 2023 at 5:43 pm #168702
Anyone else’s H90 boot up and not return to the last used Playlist?
I have mine in Dual Routing mode. I had renamed the default factory playlist “H90 Default.” I then imported 3 lists from my H9. I finally made my playlist and named it “Main.”
Say I power it off on program 7 from my “Main” list. When I power it back on, it is still on that program 7. However, if I scroll up or down it scrolls through the Programs from the “H90 Default” playlist rather than my “Main” playlist. The exception is when I scroll past whatever program that loaded at power on. So, again using program 7 as an example, my “H3000” program loads while the 6 and 8 respectively are the default “JazzyBZ” and “Awaken.” I have to go into the System menu each time and change the Playlist back to “Main” to get the playlist I made.
It does this regardless of whether it’s connected to my laptop or not.
Curiously, the H90 only does this with the “Main” playlist I created. If I switch to one of the 3 Playlists I imported from my H9 the same playlist is preserved upon reboot.
Here’s a short video of the problem:
https://www.youtube.com/watch?v=PKUg5xuVjCs&ab_channel=1VHFan
January 27, 2023 at 5:54 pm #168703
Hello eruption77,
This is a known issue that only affects users in dual routing mode. It will be resolved in the next update in the coming days.
January 27, 2023 at 5:56 pm #168704
Eventide Mods, please feel free to delete this thread if you like.
After confirming the problem was only present with the “Main” Playlist I made, I renamed it to “Default” through the H90 Control. After the rename, the H90 is preserving the last used Playlist upon reboot. Not sure what, how, or why this fixed it… I didn’t change anything within the Playlist itself. I tested with the other 4 Playlists I have and couldn’t reproduce the problem–only with my “Main” playlist. Just simply renaming the Playlist has resolved it.
Thank you just the same though! LOVE this thing!
January 27, 2023 at 5:57 pm #168705
Thank you very much, Joe!
January 31, 2023 at 9:38 am #168766
This issue has been resolved in H90 software 1.3.0. Please update your H90 and let us know if you have any issues. Thanks.
June 5, 2025 at 7:09 pm #190497
When I switched to dual routing, all my presets that I made all gone =(
There was no confirmation that it will wipe out when switching to dual mode =(
Software v1.10.7
June 6, 2025 at 9:14 am #190504
Sorry for the confusion. Insert Mode and Dual Mode have 2 different Program libraries. Your Programs will still be there if you switch back to Insert Mode.
Using H90 Control, you may export your Programs from Insert Mode, switch to Dual Mode, and then import those Programs again to convert them to Dual Mode.
Let me know if you have any questions.
https://cdn.eventideaudio.com/manuals/h90/1.10.7/content/edit-modes/routing.html
June 6, 2025 at 9:22 am #190506
I actually went back to insert mode right away because I want my presets but they are all gone. I hope this gets resolved 🙁
June 6, 2025 at 9:36 am #190507
Sorry, that shouldn’t happen.
Please backup your pedal using H90 Control and send the backup to support@eventideaudio.com. We can look into the issue there.
See #1 on the list for backup instructions: https://cdn.eventideaudio.com/manuals/h90/1.10.7/content/h90-control/edit.html#parameters-edit-menu
