Home › Forums › Products › Stompboxes › H90 Looper controls and hotswitches
- This topic has 2 replies, 2 voices, and was last updated 1 year, 11 months ago by
cestlamort.
May 22, 2024 at 11:07 am #182884
I’ve been trying to figure out how to map the looper controls (play / dub / stop) to the three on-board switches, but I haven’t been able to figure out how to do so.
I have it set up to work with an AUX switch (and the one-button looper is there as a backup), but I’d like to simply map the play / dub / stop functions to the P / A / B buttons, respectively (under Perform page 1 or Perform page 2).
I’d imagine it involves mapping Play to HS1 and assigning HS1 to the P button, Dub to HS2 and HS2 to A, etc etc, but I haven’t been able to actually do it. Also possible is that I am missing something, and please forgive me if I’m still not grasping a fundamental aspect of the H90 control.
For example, I may well be confusing/conflating hotswitches and performance parameters.
I’ve had no issue setting up a 3-button AUX switch for this functionality, but I’m only using the external switch for looping control, and it’d be nice to cull it from the setup.
Also worth noting that I tend to do 95% of editing on the pedal, so there may be a way to do this in H90 control that I didn’t come across.
Thanks for any insight!
May 22, 2024 at 12:57 pm #182891
The Performance parameters [Record, Play, Stop, Empty, Undo/Redo (and the ‘missing’ functions from the TimeFactor / H9)] are only going to be available in the Preset where the Looper is loaded [A or B]. Really, you need those Aux switches or MIDI to get full functionality out of the Looper.
The HotSwitches live in a parallel universe. You can map all three to specific parameters inside a single Preset. I often edit onboard, too. In this case, it will be much easier to see the overall picture of HotSwitch programming in H90 Control.
May 22, 2024 at 4:13 pm #182892
Thanks. Nice to know that I wasn’t totally missing/misunderstanding things. It’s a bit frustrating (“there are switches *right there*!”) but it makes sense, given the preset+switch relationships.
