Home › Forums › Products › Stompboxes › H90 Global/Default Insert routing
- This topic has 3 replies, 3 voices, and was last updated 11 months, 2 weeks ago by
budworth.
March 5, 2024 at 12:26 pm #178687
Request for H90:
Global (or customizable default) setting for the insert loop in the routing menu. I have my H90 set up with a stereo loop, and it feels a bit repetitive to have to set mono loop 1, mono loop 2 until they’re stereo and then move to the desired spot in the signal path.
(tangent: I’ve been using a naming convention of “^” for the loop placement in the preset name. Ex: “chorus^reverb”, “^echo ultratap”, “detune delay^”, sometimes with a (effect name or type or number) so I remember what worked best as I was goofing around)
Requests for Eventide forums:
- Jump to unread posts function for threads
- Digest or single email for new posts in subscribed threads (for example, I enjoy this discussion and have subscribed but I’d rather not get a new email with every new reply. Yes, I can set up my mail client to sort things, of course).
March 5, 2024 at 4:22 pm #178756
Thanks for your request. I’ve moved it to its own thread so other users can comment/upvote this feature request. This has been requested before and we have discussed the option of adding this, if many users are interested in this feature that could help us decide if we will pursue it.
March 5, 2024 at 10:53 pm #178781
“Global (or customizable default) setting for the insert loop in the routing menu. I have my H90 set up with a stereo loop, and it feels a bit repetitive to have to set mono loop 1, mono loop 2 until they’re stereo and then move to the desired spot in the signal path.”
If this is the feature under consideration, I’d call this a minor quality of life improvement.
I too run a stereo loop all the time. I see how the suggestion would make things a bit easier when creating programs from scratch. But I almost always create new programs by modifying existing programs. That way, insert settings, most footswitch settings, and some hotknob settings are already set to my default choices.
I use the ^ symbol as an apostrophe. It’s ok, but I’d like to see some more special characters for naming. Somewhat relatedly,it’s nice that I can highlight/copy/paste (with a mouse) program names (using Windows 10). But I can’t highlight/copy/paste preset names.
May 18, 2025 at 8:19 pm #190205
Bump! This feature is a must.
