Home › Forums › Products › Stompboxes › H90 Feature Request: Global Kill Dry MIDI CC#
- This topic has 16 replies, 3 voices, and was last updated 2 years, 12 months ago by
Lodeman.
May 2, 2023 at 5:53 pm #170879
Hello!
Request: Add a Global Kill Dry Parameter (MIDI CC#)
Thanks
May 2, 2023 at 6:56 pm #170882
Can you be more specific about your request? You’d like to have a CC that toggles the Global kill dry setting on/off?
What is the use case for turning kill dry on/off with a controller like this?
Note that you can currently map the Program or Preset kill dry parameter on/off using a CC in H90 Control.
May 2, 2023 at 10:45 pm #170890
“You’d like to have a CC that toggles the Global kill dry setting on/off?”
Yes!
However, it would be helpful if we could assign global source controls for Program parameters (mix, in, out..)
For example, If I always want to assign a Hotknob to control the “P In gain” I have to assign program by program…
I have the hotknob controlled by midi (expression pedal) and use it to swell without lost the tails when going to heel position (in gain -60).
May 3, 2023 at 10:09 am #170903
Thanks for clarifying. This can be done with the current software, just not in the way you are attempting to do it.
Program in gain, out gain, and mix can all be assigned to global controllers, but the control source must be a MIDI CC, aux switch, or expression pedal (not a HotKnob).
If you set your expression pedal to control global P input gain, this will accomplish what you are looking for.
https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/appendix/global.html
Let me know if you have any questions.
May 3, 2023 at 1:27 pm #170934
Thanks for replaying!
It works as a MIDI CC. Thanks for that!
But it doesn’t work as intended if I assign an aux switch as a global control.
When Global, the aux switch behaves as a momentary switch. Not as a latching.
For example, if I assign a aux switch to P in Gain, when I press goes to 12db and when I release goes to -60.
This is a problem, because when I assign the aux switch inside a specifc Program, it works as intended (like a latching), but when assigned to GLOBAL or MIDI TRANSMIT it works as a MONETARY switch. Maybe there is a problem here…Should work as a Latching for both.
Thanks again!
May 3, 2023 at 2:17 pm #170943
You’re welcome.
What aux switch are you using? I just tested this and my aux switch has latching behavior. Note that you’ll need to use a momentary normally open aux switch for it to function properly with the H90.
Also, make sure that you’ve set the input to use an aux switch and calibrated it before testing. This is configured in System Settings > I/O.
May 3, 2023 at 2:42 pm #170946
I’m using this one:
http://www.moskyaudio.com/product/products-7-37.html
It is a momentary normally open device.
I have already calibrated.
Even using it as with midi transmit? Or Global?
Because, as I said, it works perfect inside the program.
May 3, 2023 at 3:11 pm #170947
Thanks for the info. I can’t reproduce this behavior with my aux switch. It always acts as a latching switch, even with global mappings or MIDI transmit.
May 3, 2023 at 3:20 pm #170948
Ok. Thanks. So the problem is on my end. Appreciate your patience.
I will try another switch and I’ll let you know how it goes.
May 3, 2023 at 7:40 pm #170958
Not working for me…
I’ve uploaded a video to show the issue.
Thanks again!
May 3, 2023 at 7:42 pm #170959
May 4, 2023 at 9:38 am #170978
Thanks for sharing the video. It does look like your switch is behaving correctly, and I was testing this with the wrong (latching) type of aux switch. Sorry about that.
Mapping aux switches directly to knobs only supports momentary behavior. You could globally map your aux switch to a momentary Hot Switch and then map the P in gain to that Hot Switch as a work around.
May 4, 2023 at 1:03 pm #170985
Is there any possibility to implement support for latching behavior?
Momentary behavior has a very restrict use, mainly with midi.
Thanks
May 4, 2023 at 3:11 pm #171001
Yes, I can log your request and it may be added in a future update.
May 4, 2023 at 7:36 pm #171024
Throwing more hardware at an issue isn’t always the best solution. But, as Tyler alluded to, a latching switch does get you where you want to go. I’ll simply add that something like a Boss FS-6 or FS-7 will configure either switch (or both) as momentary or latching.
May 4, 2023 at 9:46 pm #171026
Thanks for considering the request.
May 6, 2023 at 6:24 am #171055
The behavior is different for the same source control.
For example, if I use switch 1 for controlling any parameter in a program and the same switch as a global cc#, it will not work for both. Because for the program the behavior will be latching and for the global assignment momentary.
Sorry, but the way it is now is almost unusable. Very restrict use.
