Home › Forums › Products › Stompboxes › H90 EQ Use Question
- This topic has 2 replies, 2 voices, and was last updated 2 years, 7 months ago by
Navyvet1125.
September 15, 2023 at 9:27 pm #174188
I recently purchased my H90, and I am really enamored with the versatility I have with it, especially its bank mode. I’m utilizing external synthesizer and looper/rhythm pedals along with my H90, to sort of create a one-man band kind of setup, with Bank mode. For example: I have one bank named “Jazz Band”, with two of the programs utilizing the synth pedal as an insert. Basically, I’m in Bank mode, and every time I switch between programs, I can play one of three different instruments (Guitar/Lead, Bass, or Keys/Pads).
Since I’m using a synth pedal, I thought I should make the “A” algorithm an EQ to make it sound more realistic. However, I feel like maybe I might be wasting a slot with an EQ algorithm. Any thoughts and or tips? Am I even using the EQ correctly?
Thanks for reading
September 16, 2023 at 8:52 am #174193
Using a keyboard synth, there’s often enough onboard to tailor frequency ranges (filters, etc.). Depending on which synth pedal you’re using, you might not have as many options for that.
I don’t think using the EQ Compressor is ‘wasting’ a slot, necessarily. If it does what you’re after, then it’s useful in the chain. Especially if you need to target specific frequencies with parametric accuracy, or compress them.
But since you’re relatively new to the H90, I’m going to make a suggestion: Go through all of the algorithms, and note which ones *also* have EQ parameters available.
Many have at least a low & high shelving filter; others add mid frequency & level. You just might find what you need, and have a ‘bonus’ reverb-distortion- delay-pitchshift .. in that slot.
Another suggestion would be to run through the online manual’s Algorithm Guide first. That way, you can narrow down the ones you’d like to try out first.
September 19, 2023 at 5:07 pm #174236
Using a keyboard synth, there’s often enough onboard to tailor frequency ranges (filters, etc.). Depending on which synth pedal you’re using, you might not have as many options for that. I don’t think using the EQ Compressor is ‘wasting’ a slot, necessarily. If it does what you’re after, then it’s useful in the chain. Especially if you need to target specific frequencies with parametric accuracy, or compress them. But since you’re relatively new to the H90, I’m going to make a suggestion: Go through all of the algorithms, and note which ones *also* have EQ parameters available. Many have at least a low & high shelving filter; others add mid frequency & level. You just might find what you need, and have a ‘bonus’ reverb-distortion- delay-pitchshift .. in that slot. Another suggestion would be to run through the online manual’s Algorithm Guide first. That way, you can narrow down the ones you’d like to try out first.
I’m using a Boss SY-200, so I can switch between Bass and Organ with the press of a button, via MIDI. I’ll be sure to go through and look Algorithm Guide. Thanks for replying to my post!
