Home › Forums › Products › Stompboxes › H90 dub style delay using send level
- This topic has 8 replies, 3 voices, and was last updated 8 months, 3 weeks ago by
brock.
August 8, 2025 at 5:51 pm #191444
Hi everyone! I am trying to set up a ‘dub style’ delay effect to act on the output of a basic looper.
I have the basic looper loaded in slot A and a delay effect in slot B. I would like to be able to assign ‘delay send level’ to a quick knob for slot B.
(At the moment the closest I can get is having ‘mix’ assigned to the quick knob – but of course when this is turned down, the delay effect disappears.)
Being able to assign ‘send level’ to the quick knob would allow me to momentarily crank up the delay send level – then quickly turn it down again and the delay effect on the output of the looper would continue – dub style. (There would be loads of feedback already set up)
Anyone know how I can achieve this? Possibly it is to do with routing?
Thanks
Simon
August 8, 2025 at 10:21 pm #191446
It seemed a little awkward to use a Quick Knob for this. I don’t use them much beyond System settings. I tried various In & Out Gains, Mix controls, Series, Parallel … None of them really covered all your criteria.
The simplest way would be to use a Perform switch. For Preset B, Bypass (M) or Bypass, and save the Program just like that. I’m assuming that you have DSP selected in the Global – Program Bypass Mode.
The Program will load with Preset A Looper active and audible. Pressing Preset B – Bypass (M) will kick in the delay following the Looper. Releasing it back to Bypass keeps the ‘loads of feedback’ trailing after it.
Not really a send, as much as a solo switch. As an alternative, Repeat (M) will perform in much the same way, but the delay mini-loop will be quickly gated when you release the switch.
August 9, 2025 at 6:26 pm #191453
Hi again! When you said to ‘use a perform switch’ – do you mean a foot switch or even a hotswitch? Cheers
August 9, 2025 at 3:02 am #191448
Thanks a lot for the idea brock!
Yeah I agree a quick knob is awkward! My original idea was to just want to prove it works first. Then- after it’s working with a quick knob – I could get an expression pedal to control it or similar. I have an ‘elektron analogue heat + fx’ effects unit and that does allows you to run the delay effect either ‘wet dry’ style or ‘send’ style so was hoping the h90 would have similar facility.
But- I’ll try your perform switch solution and report back! (By way, the use case here is for vinyl DJing – I have the h90 connected to the send and return on my dj mixer. )
August 9, 2025 at 11:14 am #191449
…Then- after it’s working with a quick knob – I could get an expression pedal to control it or similar …
I’m guilty of assuming that everyone uses at least one EXP pedal with the H90, so I left that option out. It’s one of the more versatile & controllable ways to get you where you’re going.
For similar uses, I usually target the Feedback parameters directly for external control. Just be careful with the maximum range limits. If your selected delay algo goes from Feedback 0-110, you can often hit self-oscillation by the upper 90’s.
With an EXP or AUX / HotSwitch mapping, I tend to place a little bit of Feedback at the default minimum range (around 5 or 10). That forces a smoother fadeout when approaching EXP – heel, or H/S release / OFF.
It would also allow for a background slapback on the looping. Preset B Mix & Feedback(s) set fairly low, then both mapped to increase greatly under foot control.
… I have an ‘elektron analogue heat + fx’ effects unit … (By way, the use case here is for vinyl DJing – I have the h90 connected to the send and return on my dj mixer. )
Nice rig, and to me, an interesting H90 application. You may already have some other options available, for mapping the ‘swell’ over MIDI.
August 10, 2025 at 9:21 am #191455
Yes I do. I tend to group everything you can find by clicking on the PERFORM knob and the 3 corresponding LEDs as perform switches. I’d include the use of the Bypass (M) in the 1st example.
- Map one or many parameters to a HotSwitch, for instant transitions. As a parallel, jumping immediately from Heel to Toe on an EXP pedal, skipping the values in-between. It can have a momentary action, or latch & unlatch.
- When using multiple HotSwitches, clicking on one overrides the rest. It’s possible to set up 4 unique “Programs” inside of one Program, with variations over both Presets.
- Much the same using one or two 3-way AUX switches, for external control instead of the onboard switches.
- The actual Performance destinations are specific to each algorithm & Preset location. You’ll find parameters among these that can’t accessed anywhere else.
In your listed case, something like 1-BTN looping control in the Looper. Depending on the delay algorithm, Repeat or Repeat (M) to freeze & loop whatever is currently in the delay buffer.
August 10, 2025 at 7:04 pm #191456
Amazing – thanks so much for all the info!
August 11, 2025 at 1:13 pm #191464
This was an interesting read.
When building a program I tend to default to mapping a Hot Knob (on an expression pedal) for things like this, on the basis that I think I need/will use the intermediate values. Usually though, I just end up slamming the pedal either heel or toe, which means I could be using a Hot Switch. I recently added a mapping for the end of a song where I want a delay loop to persist but fade out over several seconds, and so I set up HS3 to do this, freeing up the exp pedal for dialing in tone between other parts of the song. It works great!
One way to think of a HS is as a way to immediately apply a particular set of parameter values, you can use it both directions (ON and OFF — which goes back to the program values), or just one way.
August 12, 2025 at 9:44 am #191471
… I recently added a mapping for the end of a song where I want a delay loop to persist but fade out over several seconds, and so I set up HS3 to do this, freeing up the exp pedal for dialing in tone between other parts of the song. It works great!
The amount of overlap among the control mappings can be liberating. For example, any HotKnob mapped to a subset of parameters, the EXP pedal to its own specifics, then map EXP to that HotKnob, as a ‘macro’ controller. Or the Preset (A) & (B) HotKnobs for making their own parameter adjustments, each mapped to the (P) HotKnob, as an override for both Presets.
The current value / treadle position of EXP pedals are saved, so that can be used as an initial startup position upon loading (to be adjusted & overridden later on). Once you start folding in HotSwitch maps & Performance switches, or a 2nd EXP, AUX switches, that’s a lot of possibilities packed into a single Program. The default settings with HotSwitches alone can be 4 Program alternates.
I often wish there were a couple more Perform ‘pages’ added, like in the newest Looper update. It’d be useful to have a bypassing page, HotSwitches page, utility control page, preset-specific page, … As configurable as it currently is, just with more control slots brought to the surface.
