Home › Forums › Products › Stompboxes › H90 Control Ver. 1.8.16 – Wont connect
- This topic has 21 replies, 5 voices, and was last updated 10 months, 4 weeks ago by
MaxRB.
December 15, 2024 at 11:12 am #187006
H90 Control times out and wont connect on a new PC running Win 11, H90 is running Software 1.8.6.72
Error message:
[TRPCMessageBroker.h:283].TRPCMessageBroker<struct trpc::msg::MessageT,struct trpc::msg::Message,enum trpc::msg::MessageType>::sendMIDIRequest >
Timeout waiting for response: Expected Response ID(0x71)
I am looking for suggestions, I am not sure if it needs to be paired via bluethooth,
thx for any info in advance
December 16, 2024 at 8:51 am #187034
There is no support for Bluetooth on Windows so that is unrelated to the issue you are having.
Are you running any antivirus software on your PC? Specifically, are you running Norton or Avast? Some customers have reported connection issues with these antivirus softwares after some recent updates.
If you can try disabling or fully uninstalling your antivirus software and seeing if that resolves the issue, that would be helpful.
We are looking into improving this issue.
December 26, 2024 at 5:11 pm #187204
Still waiting for some resolution, I wonder if this is an isolated incident when running Win 11, Anti virus seems to be an issue and it has been disabled, followed all suggestions from support, no cigar …. I am able to run it on a Win 10 laptop, no issues.
January 2, 2025 at 2:23 pm #187358
No resolution and or suggestions yet, I see a fair amount of issues listed by others but I am still waiting for support, more money into different cables, a new C to C cable, along with all previously suggested methods …… no worky ..
January 2, 2025 at 2:55 pm #187363
What antivirus software are you using? One of our testers has reported that updating to the latest version of Norton has resolved the connection issue they were having. If you are using Norton, can you please try updating to the latest version?
January 2, 2025 at 3:04 pm #187366
Norton 360, its up to date, still fails
January 3, 2025 at 11:42 am #187430
Sorry to hear you are still having issues. We are working to track down this issue.
Please email support@eventideaudio.com and we can troubleshoot the issue further there.
January 4, 2025 at 3:49 am #187447
I’m facing the same problem…
I’m in contact with the people of the Eventide Support but, so far, what they suggested didn’t work.
Different cables, different PC, same problem.
And the USB connection is ok, as in Recovery Mode I can see the H90 as an external drive, allowing upload and download of files.
This is truly annoying…
January 4, 2025 at 8:09 am #187453
I am able to connect by using a Win 10 laptop from my job, it is not ideal but I was able to backup my presets while I wait for a fix on my Win 11 PC, such an great piece of hardware, buggy application, I am hoping they will come up with a fix.
January 4, 2025 at 10:49 am #187454
I’ve just discovered a possible workaround with Win11+Norton360:
- I open H90 Control
- I click on the “cloud” as if I should have to update the H90 firmware
- I click on the “Done” key (top right)
- As I’m back on the H90 Control homepage, I click on “Connect” and… bingo!
I have to follow the same sequence each time I open H90 Control, but it works.
I really hope this could be helpful for all the peaple having the same issue and especially for Eventide people in order to solve it.
January 4, 2025 at 12:13 pm #187455
I do not have the “cloud” fidget on H90 control, I did have it while running the Win 10 Laptop and was able to update the hardware, no option on my end to follow the steps you listed, I am glad you got it going, my guess is that if I had an older version I may have the cloud for updating, not sure if I can install a different version of the control software so I can try this approach, Thanks for the info.
January 4, 2025 at 3:41 pm #187457
I have the latest version both for the H90 Control and H90 firmware.
For “cloud” I mean the cloud shaped icon on the right of the “Connetc” button (see the attached pictures)
You must be logged in to view attached files.-
January 4, 2025 at 4:13 pm #187460
I did have that while using Win 10 Laptop, the version for the H90 control I have on the Win 11 PC is, Ver. 1.8.16 and it does not show the update icon, anywhere.
I wonder if I can get an older version and force the update that way, the version for the hardware is 1.9.10.185, I appreciate the info.
January 6, 2025 at 9:49 am #187470
Sorry to hear you are still having issues. Your pedal and H90 Control versions are both up to date, there is no update necessary.
I do not understand how there is no update icon displayed in the app, this will alway be there, although it may be greyed out if the device is unavailable.
I would be helpful to share a screenshot of what your H90 Control landing page looks like. Please respond to your support ticket with a screenshot and we can go from there.
January 6, 2025 at 11:57 am #187494
Its a new PC, the H90 has yet to be added, second pictures shows when it fails to be added, the cloud does show but only if I use the work laptop running Win 10, I am not sure if the fact that it has yet to be added that it does not show the cloud.
January 6, 2025 at 12:00 pm #187495
Ok, the update icon is only available once a device has been added.
Sorry, I don’t have anything further to suggest right now. I will contact you further via the support ticket for more information.
January 6, 2025 at 3:42 pm #187531
To add the H90 on the new PC try this:
- Uninstall temporarily the antivirus SW
- Add H90 to H90 control (should work)
- Install again the antivirus SW
With Norton 360 it worked
In this way you should be able to follow my “workaround”
January 6, 2025 at 4:52 pm #187536
That’s a good suggestion however,
I am glad to report that it is currently working thanks to the advise by support and the collaboration of another end user running Norton.
For any other users experiencing this issue while running Norton 360 Deluxe, the fix was disabling “Safecam”
I appreciate the help and hope this can help others.
January 7, 2025 at 4:39 pm #187577
I discovered that, at least with Norton 360, is not necessary to disable the full Safecam protection. Disabling Mike Protection is enough
January 7, 2025 at 6:30 pm #187580
I just tested it and indeed works, the safecam worked but I had to reboot it at times, seems good for now, thanks for the info!
January 14, 2025 at 11:33 pm #187708
Thanks for the tip on disabling Norton Safecam, I couldn’t figure out how to get it to connect, but that did the trick!
June 6, 2025 at 1:36 pm #190511
Disbling Mike Protection worked. Thankyou !!!
