Home › Forums › Products › Stompboxes › H90 Control Latest
- This topic has 3 replies, 1 voice, and was last updated 2 years, 3 months ago by
Eventide Staff.
Viewing 3 reply threads
May 1, 2023 at 4:10 pm #170817
H90 Control Releases
June 15, 2023 at 3:08 pm #171969
1.4.1 (Requires H90 firmware 1.5.6)
Features/Improvements
- Enter algorithm parameter values by clicking on knob label for basic numeric parameters
- Moved recovery mode for updates to main menu and no longer require a recovery mode device to be added
- Added tooltip to bank name with edit instructions
- Add H90 Control version check on startup and provide link for direct download
- Added MIDI program change offset (PC Offset) to system settings
- Maintain program selection in Programs view after drag and drop to program list when possible
Bug Fixes
- Resolved issue where alert windows could wind up behind the app or not centered by using custom message box
- Fixed issue with importing H9 TriceraChorus presets
- Windows installer now checks to see if app is running and requires closing
November 22, 2023 at 9:07 am #176029
1.7.1 (Requires H90 firmware 1.6.11+)
- Supports connecting to multiple H90s at the same time with support for floating windows
- Copy/Paste between connected devices
- Improved MIDI CC selection UI
- Reduced connection time over USB
- Reorganized large menus for smaller displays to prevent scrolling
- Miscellaneous minor UI improvements
- For macOS: Bluetooth support (Requires 1.7.1 firmware to be released on 11/27/2023)
- USB still required for software updates
- USB will always be the fastest way to communicate with the H90
Bug Fixes
- Resolved issue where a program could be saved to slot 100
- Disallow copying Programs between devices with different routing modes
- On some delay algorithms subdivision drop down menu was selecting wrong value
- Bank names are now exported/imported
January 25, 2024 at 12:08 pm #177675
1.7.6 (Requires H90 firmware 1.7.5+)
- Add Backup/Restore for user content (Programs, Lists, Presets) and system settings
- Add a utility for retrieving logs from the pedal
Bug Fixes
- Fix an issue where Programs would sometimes not appear on initial connection
- Fix Import of H9 lists
- The topic ‘H90 Control Latest’ is closed to new replies.
