Home › Forums › Products › Stompboxes › H90 and A&H Xone 96 midi control
- This topic has 6 replies, 3 voices, and was last updated 3 years, 1 month ago by
brock.
February 24, 2023 at 7:49 am #169391
Hi, I’m getting very confused – so any help would be appreciated.
I’m trying to simply activate / deactivate a program on the H90 using a midi command sent from my Xone 96 mixer.
On my system, setting I have:
And on my program settings I have:
I have set my Xone 96 to send on channel 16 and have using a button that corresponds to 18.
When I put a monitor on the midi out from the Xone 96 I see:
But nothing happens on the H90.
Where am I going wrong?
Mike
February 24, 2023 at 8:19 am #169392
You are trying to trigger Active & Bypass with MIDI Notes. These are not supported in the H90. You will have to use MIDI CC messages, if that’s possible.
I’m not familiar with the Xone 96 capabilities. A workaround might be translating MIDI Notes to MIDI CC, using an ‘event processor’, but that will require more hardware / software in the MIDI pipeline.
February 24, 2023 at 9:38 am #169393
Thanks BROCK – that really helped and I’ve got it sorted. I can can now activate / deactivate effects direct from my mixer. 🙂
February 24, 2023 at 4:18 pm #169403
I knew I had run across the Xone 96 at some point [Elektronauts]. That’s one badass mixer, if a bit too RCA / DJ-centric for my own use. I had no idea what the MIDI implementation might be. Glad you got it all worked out.
March 23, 2023 at 6:50 pm #169899
Hi there, thanks since now for the help, I have a xone 96 and I want to use it as a midi controller of traktor 3
March 23, 2023 at 6:51 pm #169900
what I should do?
March 23, 2023 at 7:53 pm #169901
Allen & Heath will do a much better job of walking you through it than I ever could. Lots of video tutorials. Search “Xone 96 MIDI”.
