Home › Forums › Products › Stompboxes › H9 Volume too loud even Bypassed
- This topic has 7 replies, 6 voices, and was last updated 10 months, 3 weeks ago by
leafbelly.
May 4, 2017 at 10:23 pm #114141
I use it in a looper (Glab GSC4) but recently I noticed something very annoying and never noticed before.
When H9 is in the loop, the volume is far louder then when is not. the problem happends ever the preset is active or not.
So my H9 adds an extraboost that I’ve never heard before, and so I have to compensate every presets volume.
Why ? and how coming back ?
May 4, 2017 at 10:26 pm #146295
I'm thinking this is something at your end (sorry). The H9 does not boost the signal when the preset is not active.
When it is active it is possible to increase the level on a preset by preset basis, but it does not sound like this is what is happening.
Does it do this on relay bypass ?
May 4, 2017 at 10:28 pm #146296
to be complete : have to say that
– before, my volume pedal was after looper/selector
– now my volume pedal is between guitar & looper/selector
October 30, 2018 at 10:59 pm #150429
silly question but do you have the GSC4 buffer on?
May 20, 2023 at 1:31 pm #171367
I am having the same issue- presets on the H90 are bypassed, and I’m using a Crocodile Tail loop- so I can very easily take it in and out of the signal chain to A/B. I active its loop with no other pedal active in the signal chain and there is a significant volume bump. Is there an easy Global trim setting so I can bump the global volume down?
June 12, 2025 at 8:10 pm #190615
was this ever resolved. I’m having the same issue. I have confirmed it’s the H9 as its fine when i bypass that pedal manually in my chain.
The sound clean/bypass sound from all of my guitars is distorted, even on single coils.
the only thing I’ve done different lately is add an expression pedal.
June 13, 2025 at 9:46 am #190623
It sounds like you are doing something to increase the gain once the H9 is active, possibly related to the expression pedal.
When connected to H9 Control, you should see a dropdown menu that shows “More” in the top right corner. Click this and check if the EXP pedal is set to control the input or output level.
June 13, 2025 at 1:04 pm #190624
I was able to resolve it by changing the bypass mode from DSP to relay. I’m not sure why it would affect the output level like that, but I suspect there may be other issues with the pedal.
Thanks a lot for the reply!
