Home › Forums › Products › Stompboxes › H9 – simple presets list organizer?
- This topic has 9 replies, 2 voices, and was last updated 3 years, 10 months ago by
Reji.
September 24, 2020 at 8:41 pm #116116
Hi everyone,
Found many old posts on this topic, all pointing to videos… however, since it’s 2020 now I figured I would ask again (wishful thinking): is there any better way to organise presets in a list than to use H9 Control? MacOS or iOS, they’re both as unusable as the other…
Ideally:
- something that works in list mode (these boxy icons do not work for a long flat list of 90+ presets)
- something that lets you reorder presets easily (move it between 2 existing presets, drop it)
- something that lets you copy & paste from one list to another
Of course some hierarchy / patch bank organization would be rad but frankly, just a decent list editor would go a long way.
I’m happy to edit an XML file in vi/notepad for that matter – anything but H9 Control.
I love the H9 sounds but boy, the software does not live up to it!
Please tell me I’ve missed something great out there. Thanks!
September 25, 2020 at 1:23 am #155892
I am not 100% sure, but I think that preset list is just a text file. So, you can edit it in text editor, I guess.
Another think is how to send it to H9 without H9 Control.
September 25, 2020 at 2:33 pm #155900
1. See attachement 1 (5×5 grid & drag & drop), where you can change the view to a 5×5 grid.
2. You can click "Drag & Drop", where you can just drag & drop presets
3. See attachment 2 & 3 (Copy preset, Save preset), where you can copy a preset from a list, and save it to another list.
September 27, 2020 at 6:45 pm #155916
Glad it has helped.
It would be cool, if Eventide added tabular mode for organizing presets. More than 25 on page, sortable collumns. And possibility to open two lists and to copy between them. At least for PC versions.
January 8, 2021 at 11:15 pm #156823
This thread is kinda old, but it may have some relation with Preset tidiness… been expecting this update for a while
Also mentioned the UNDO button but for all purposes, even when tweaking sounds…
April 17, 2022 at 10:17 am #163484
ON a Mac
Can you just go from GO > Library > H9 Control > Preset Lists ??
within that folder are the preset lists. you can compare them to each and drag / drop / delete as necessary. seems pretty easy.
HOWEVER, I don’t have my pedal hooked up right now, so not sure if this will work. can I open h9 control without the pedal and check?
seems like the easiest way to organize if you have a lot of presets and lists
July 4, 2022 at 11:51 am #164308
I also found it very confusing. I can’t create even two preset lists. In the manual there is no examples.
2. You can click “Drag & Drop”, where you can just drag & drop presets
Thank you Bohan, I appreciate it. It does help somehow but it’s still super unwieldy and finicky (the fact that we have to even exchange about it is proof of it).
The main problem, after the learning curve of understanding the mechanics of what you suggest is that there is no “undo” (I think?). Since the “drop zone” is quite small one thing that *always* happens at least once when moving presets around is that you either:
- drop the preset in the wrong place, not exactly in the drop zone (and the preset you were moving disappears)
- drop the preset on an another one (making that existing preset disappear)
A painful workaround is to save at each and every step and close/reopen the file when it happens… but when editing a 99 preset file it’s a bit painful.
Thanks for the response in any case, I appreciate it.
Hey, you are right: it’s just JSON files zipped together! I should have thought about it. Editing that JSON file is actually far easier than using the graphical interface (if you are used to it). Thanks for pointing me in that direction!
└── PresetLists
└── 3 2020-02-23 H9-DMD-pedal-presets
├── 0001 WARMTH.tide
├── 0002 BIG CLONE.tide
├── 0003 I WALK ALONE.tide
├── 0004 RECORD HEAD.tide
├── 0005 BE WOWED.tide
├── 0006 WARPED RECORD.tide
├── 0007 STREETS.tide
├── 0008 CLASSIC CHORUS.tide
├── 0009 LONG OLD DELAYS.tide
├── 0010 LONG VINTAGE2.tide
├── 0011 BALLERINA.tide
├── 0012 1984LEGS.tide
├── 0013 3 OCTAVE RANGE.tide
├── 0014 POWERCHORD.tide
├── 0015 SHATTER.tide
├── 0016 INSANITY BUILD.tide
├── 0017 RISING SWIM.tide
├── 0018 DLYOCTAVE.tide
├── 0019 CLASSIC CRYSTALS.tide
├── 0020 CARNEGIE HALL.tide
├── 0021 SHIMMER.tide
├── 0022 ULTRATAP.tide
├── 0023 ULTRASWELL.tide
└── metadata.tidel
September 29, 2020 at 5:32 am #155927demed wrote:
The main problem, after the learning curve of understanding the mechanics of what you suggest is that there is no "undo" (I think?). Since the "drop zone" is quite small one thing that *always* happens at least once when moving presets around is that you either:
There is an "Undo" button at the top right corner. See attached screenshot.
Yes, it does take some time to learn and I admit it could be improved. If you'd like to drop a preset to the grid without replacing any existing preset, you need to drop it between 2 preset blocks. The gap between 2 blocks will be highlighted if you move the mouse there.
