Home › Forums › Products › Stompboxes › H9 does not boot anymore
- This topic has 4 replies, 4 voices, and was last updated 10 months, 3 weeks ago by
Eventide Staff.
November 14, 2016 at 5:17 pm #113816
I bought my h9 in the U.K. About 6 weeks ago and it survived a month tour.. on the first date abroad in the Netherlands it dies. It will go through its boot sequence and then when it should display the patches it just gives a blank screen.. tried restarting, factory reset but nothing. When I do the factory reset the display doesn’t how the right characters somethimes ending up with a random letter on the screen or just blank but the unit won’t restart..
Severely annoyed cause I can’t get back to the shop til after our tour!!!
Anyone have anything similar? -
November 14, 2016 at 7:20 pm #144870
If it will go through the boot sequence, you should be able to get it into update mode. If so, you could run the update which should rebuild the software.
I'm concerned that we don't know why this happened, as it may point to some kind of hardware issue. But, my guess is that right now you are mostly interesting in getting it working.
November 14, 2016 at 9:11 pm #144871
That did it! I didn’t realize that there is an update mode outside of the H9 app which I couldn’t connect.. update mode worked and managed to re flash..
I have no idea how it happened but I will post again if it happens again..
I couldn’t find anything about this problem on the forums so thought it might be hardware but all seems well for the time being.. fingers crossed..
Thanks for the help! -
June 7, 2025 at 10:36 pm #190526
I’m having the same problem, it boots up and then goes to a 1 on the right hand side of the screen and then dies. How do I get into update mode?? It dies too fast to connect via bluetooth and it won’t connect via USB
June 9, 2025 at 2:20 pm #190545
Sorry to hear you are having issues.
Please email support@eventideaudio.com and we can help you further there.
