- This topic has 6 replies, 5 voices, and was last updated 9 months ago by
Eventide Staff.
February 10, 2023 at 2:26 am #169017
If I go to press load I can find the presets in the folders, but I can’t scroll through them within the plug in window. How can I fix this?
February 10, 2023 at 8:47 am #169021
It looks like you are using Logic’s preset browser. There is a preset browser built into the plug-in that you should use instead.
At the top of the plug-in UI above the Eventide logo, there are save/load buttons as well as +/- buttons that will allow you to scroll through the presets.
April 14, 2023 at 6:39 pm #170461
how did you solved this problem ? I have the same, im clicking on right place, and presets are not showing up…
April 18, 2023 at 2:44 pm #170533
Hi, are you looking in the plug-ins preset browser (NOT the Logic browser)?
July 26, 2025 at 1:01 pm #191125
I am having the same problem, I am using the Eventide built in browser, I just downloaded. I have a M1 Mac. Please help! NO presets
July 26, 2025 at 1:32 pm #191126
I forgot to say in my last post that I only downloaded the Audio Unit plugin. Could that be the issue, I thought Logic is compatible with AU only? No Presets, using Eventide preset browser, very frustrating
July 28, 2025 at 9:24 am #191134
When you run the installer there is a box to check for presets along with the other plug-in formats. Please run the installer again and make sure that box is checked, you may have unchecked it if you were unchecking the other formats besides AU.
If you still have issues, please email support@eventideaudio.com.
