- This topic has 14 replies, 9 voices, and was last updated 5 months, 2 weeks ago by
medway.
December 20, 2022 at 3:03 pm #167864
are all the functions in your H3000 DELAYS plugins also included in the H3000 FACTORY plugin?
December 21, 2022 at 10:54 am #167870
No, they are different plug-ins that are used for different purposes. H3000 Factory is a re-creation of the Patch Factory, Mod Factory 1, and Mod Factory 2 algorithms from the H3000. H3000 Band Delays is a recreation of the Band Delays algorithm. The easiest way to see the difference would be trying a free trial of either plug-in.
September 3, 2023 at 3:00 pm #173992
Please consider making the Magic Air patch, as found on the H3000 SE. I’ve demoed the plugin and do love it, but if it had Magic Air, i might even consider selling the hardware! BTW i own Split EQ. Talk about a lifesaver, thank you for the great products!
Rafael
September 13, 2023 at 8:54 am #174157
Please consider making the Magic Air patch, as found on the H3000 SE. I’ve demoed the plugin and do love it, but if it had Magic Air, i might even consider selling the hardware! BTW i own Split EQ. Talk about a lifesaver, thank you for the great products! Rafael
You can make it yourself. I did on mine.
September 27, 2023 at 7:04 pm #174378
What is the recipe?
September 27, 2023 at 7:15 pm #174379
What is the recipe?
I’ll post the preset. Original uses Multishift algo so might not be 100% but from what I remember it’s close. Will check against the hardware.
October 12, 2023 at 11:29 am #174708
What is the recipe?
please post this preset been looking everywhere ! Thank you 🙂
October 12, 2023 at 11:47 am #174711
What is the recipe?
Hi you can try this one. I made it a long time ago and not sure how it compares to the hardware. When I find some time soon I will check it but see what you think. It’s probably not exact as it uses a different algo but should be similar.
You must be logged in to view attached files.-
March 18, 2025 at 2:33 pm #189130
Thx for posting your Magic-Air patch. Much appreciated! 🙂
November 12, 2025 at 4:57 am #193284
Hey there, not sure how to download this? I “download” it, then tried to move it into both the band delays plugin preset folder and the Factory mk II preset folder (wasn’t exactly sure which it was made in) and neither of them had any data when actually loaded in the plugin in my DAW (Logic). Any ideas? Or could you share settings so I can recreate it myself? Thanks!
October 14, 2023 at 12:59 pm #174817
Thank you!!
May 2, 2024 at 2:45 am #181869
Thanks for sharing ! I will try it out in the new updated MKII plugin..
May 2, 2024 at 7:45 am #181889
Can confirm it sounds great and have used it a lot in my mixes. 💪
May 8, 2024 at 9:34 pm #182541
Glad it was useful!
November 12, 2025 at 7:20 am #193285
What did the file extension look like? it should be .tide and you should see other presets with .tide for the extension. It’s Eventide’s own format not VST or AU.
This is for the Factory plugin.
