- This topic has 3 replies, 2 voices, and was last updated 3 years, 11 months ago by
Eventide Staff.
May 30, 2022 at 1:27 pm #163890
HI
H3000 Band Delays Native In Logic Pro 10.4.4 can’t open , my OSX is Sierra 10.12.6
The following Audio units message appears
validating Audio Unit H3000 Band Delays by Eventide:
AU Validation Tool
Version: 1.6.1a1
Copyright 2003-2013, Apple Inc. All Rights Reserved.
Specify -h (-help) for command options————————————————–
VALIDATING AUDIO UNIT: ‘aumf’ – ‘BDls’ – ‘Tide’
dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/ERA6_DeBreath.component/Contents/MacOS/ERA6_DeBreath being ignored in restricted program because of @executable_path
dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/ERA6_DeClipper.component/Contents/MacOS/ERA6_DeClipper being ignored in restricted program because of @executable_path
dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/ERA6_MouthDeClicker.component/Contents/MacOS/ERA6_MouthDeClicker being ignored in restricted program because of @executable_path
dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/RegrooverPro.component/Contents/MacOS/RegrooverPro being ignored in restricted program because of @executable_path
dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/Rhythmiq.component/Contents/MacOS/Rhythmiq being ignored in restricted program because of @executable_path
2022-05-30 19:22:56.734 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32908800>: NSCocoaErrorDomain – 3840
2022-05-30 19:22:56.735 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32908ad0>: NSCocoaErrorDomain – 3840
2022-05-30 19:22:56.735 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32909080>: NSCocoaErrorDomain – 3840
2022-05-30 19:22:56.736 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32909420>: NSCocoaErrorDomain – 3840
2022-05-30 19:22:57.002 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32a35050>: NSCocoaErrorDomain – 3840
Manufacturer String: Eventide
AudioUnit Name: H3000 Band Delays
Component Version: 3.7.11 (0x3070B)* * PASS
TESTING OPEN TIMES:
COLD:
FATAL ERROR: OpenAComponent: result: -1,0xFFFFFFFFvalidation result: n’a pas pu s’ouvrir
May 30, 2022 at 1:29 pm #163891
H3000 Band Delays Native is well open in Ableton Live 10 suite , but i don’t use it
May 30, 2022 at 1:50 pm #163892
Thanks for answer …. but
hi
It was done at the first step of the install , the HE 3000 component is in the components file and visable in Logic pro but can’t open it
the same component is well opened by Ableton Live 10
Le 30 mai 2022 à 18:49, Eventide Audio <noreply@eventide.com> a écrit :
Your H3000 Band Delays 30-day demo has been successfully deposited into the iLok account leturk07
You can download the installers here: https://www.eventideaudio.com/downloads?product=H3000+Band+Delays
If you would like to purchase the plugin, you can do so at our webstore by following this link: https://eventide-store.myshopify.com/cart/30337491468345:1?channel=buy_button
May 31, 2022 at 1:47 pm #163906
Sorry for the issue you’re having. Please see below and let me know what happens.
Plug-in isn’t working in a DAW on Mac:
Confirm you have the latest version of your plug-in installed: https://www.eventideaudio.com/products/plugins
Confirm that you have the latest version of iLok License Manager installed.If you already have iLok License Manager installed, open iLok License Manager and select iLok License Manager → Check For Application Updates in the toolbar.
If you do not have iLok License Manager installed, download the installer at http://www.ilok.com and install.
Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
If steps 1-3 don’t solve your issue, close your DAW and uninstall the plugins.
Newer plug-ins have an uninstaller is located at /Applications/Eventide/Uninstallers.
For older plug-ins without an uninstaller, delete the following files:
AAX: Mac HD/Library/Application Support/Avid/Audio/Plug-ins/Eventide/<plugin name>.aaxplugin
VST: Mac HD/Library/Audio/Plug-ins/VST/Eventide/<plugin name>.vst
AU: Mac HD/Library/Audio/Plug-ins/Components/<plugin name>.component
Presets and Docs: ~/Music/Eventide/<Plugin Name>/ (whole folder)
Open your DAW and rescan your plug-ins, and then shut your DAW again.
Deactivate and reactivate the plug-in license in iLok License Manager.
Reinstall your plug-in.
Reopen your DAW and rescan your plug-ins.
AudioUnit only: If still not showing, some macOSes occasionally require a restart for Audio plugins to correctly scan.
Other additional things a user should check for based on their DAW:Logic:
Launch Logic Pro X
Go to Preferences->Plug-in Manager, select the desired plug-in(s) and then click “Reset and Rescan Selection”
If the plug-in(s) fails validation, then copy the output of the validation window, and send it to us.
If the plugin passes validation but still does not show in the Insert menus, try the following steps:Close Logic Pro X
Make sure Finder is the active application
While holding the Option key, click on the Go menu at the top of your screen and select Library
Delete the following files from your User Library, if they are present:
~/Library/Caches/com.apple.audiounits.cache
~/Library/Caches/AudioUnitCache/
~/Library/Preferences/com.apple.audio.InfoHelper.plist
~/Library/Preferences/com.apple.audio.SandboxHelper.plist
Then, open a Terminal window (located at Applications/Utilities/Terminal), and enter the following commands (type each command and press “Enter” afterwards):killall -9 cfprefsd
killall -9 AudioComponentRegistrar
Restart your computer
Restart Logic Pro X
