- This topic has 15 replies, 8 voices, and was last updated 6 months ago by
Eventide Staff.
May 5, 2021 at 4:15 pm #116478
Hi All,
I recently purchased the H910 Harmonizer, however only the VST2 version is available in my DAW (Cakewalk). I have a few other Eventide plug-ins and they are not showing up either. I have done the registration and iLok activation, as well as the VST scan in Cakewalk, but the VST3 version of the H910 is a no show.
Any ideas why?
Thanks in advance.
Kind regards,
Living Room Rocker
May 5, 2021 at 5:15 pm #157773
Hello Living Room Rocker,
Can you please check that all the VST3 plug-ins are "enabled" in the Cakewalk Plug-in Manager?
You can follow the instructions in this video: https://youtu.be/BFFLIQPn3DM?t=65
Let me know if that solves your issue.
-Tyler
May 6, 2021 at 9:37 pm #157783
Hi Tyler,
Thanks for the response. That’s the thing, they don’t show up in under the VSTi3 section of CW’s Plug-in Manager. Only the VST2s show in the VSTi section.
Kind regards,
Living Room Rocker
May 6, 2021 at 9:45 pm #157784
Let me correct myself and point out, I meant VST3 and VST respectively and not VSTi3 and VSTi.
My apologies,
Living Room Rocker
May 6, 2021 at 9:55 pm #157785
Hi Tyler,
I did another installation on top of the current VST3 install and it took this time. The H910 now shows under the effects. Sorry for the trouble.
Kind regards,
Living Room Rocker
May 7, 2021 at 1:06 pm #157789
No trouble at all, glad you got it sorted out!
June 18, 2025 at 8:14 pm #190657
I hate ilok. Nothing but problems. My plugin is registered but on eventide it shows up with 0 activations, the plugin does not show up anywhere in reaper or davinci resolve 20. I have uninstalled spring and pace and reinstalled 3-4 times.
June 24, 2025 at 6:30 pm #190725
Sorry to hear about the issues. Can you email support@eventideaudio.com so we can assist you further?
August 5, 2025 at 11:32 am #191399
I experienced a similar issue in Ableton Live. I installed Shimmer and (I think because of some problems with the activation) the VST3 was not visible. Multiple reinstalls didn’t help either. It was visible in Reaper though.
My fix was to quit live, delete Live’s plugin database and start it again (https://help.ableton.com/hc/en-us/articles/360000794970-Resetting-Live-s-Database).
I deleted all files, but I guess the plugin database would have been enough.
After that is rescanned all plugins and all versions of the Eventide plugins were there.
October 3, 2025 at 3:49 am #192404
Temperance Lite not showing in Studio One
October 7, 2025 at 12:06 pm #192470
Please email support@eventideaudio.com with your license key and iLok username and we can help you further there.
October 24, 2025 at 9:41 pm #192985
ILOK is soooooo frustarting. I hate it.
October 25, 2025 at 10:11 am #192991
Hi
Why did you use Ilok – bullshit – system to protect your soft !!
I got Temperance free and IMPOSIBLE to activate in Studio One 7 pro !!!!!
So, Possibly interested in other of your software but, hello, I’ll look elsewhere…
October 26, 2025 at 10:04 am #193002
Dear Eventide team, I solved this problem myself. Please share this simple solution with Studio One users:
If vst appears active in ilok, cut the Temperance Lite.vst3 folder from the Program Files/Common Files/VST3/Eventide folder and paste it into the Program Files/Common Files/VST3 folder.
This will allow Studio One to detect the invisible plugin.
October 26, 2025 at 3:05 pm #193006
My problem is that Temperance does not appear in my Ilok, so when I start Studio One 7, an Evantide popup opens and asks me for my Ilok ID and password, which I enter, and it does not work because, I repeat, Temperance is not in my Ilok and I do not know how to make it appear…
And just because this plugin is free doesn’t mean Eventide shouldn’t provide the solution!
October 27, 2025 at 12:33 pm #193037
Sorry for the issues you are having.
This sounds like there may have been an issue when you registered the license if it isn’t showing up in your iLok.
Please email support@eventideaudio.com with your license key and iLok username and we can help you there.
