Home › Forums › Products › Stompboxes › Eventide H90 MIDI PC Change and Bypass at the same time
- This topic has 37 replies, 8 voices, and was last updated 4 months ago by
Eventide Staff.
February 2, 2025 at 7:46 am #187986
I’m trying to use my Boss MS3 to change the Program on the H90 and bypass it at the same time.
I have the MIDI Bypass CC# set to 0. When I set the configuration like attached, it does indeed bypass the H90 with a value of 0 and activate it with a value of 127.
However, if I send a PC# along with it, then it doesn’t bypass. In the example attached if I set the PC to anything other than “OFF” it ignores the Bypass CC and turns the H90 into active.
I tried the same with an H9 and it works as expected, the program changes and the bypass CC correctly sets the bypass state. How can I do this with an H90?
February 2, 2025 at 8:47 am #187988
Looking at the log files I’m assuming the MIDI bypass messages are being ignored:
‼️ [TRPCMessageBroker.h:147].midiReceived > Ignoring inbound message ID:0x1d due to pendingResponseID:0x1b
‼️ [TRPCMessageBroker.h:147].midiReceived > Ignoring inbound message ID:0x19 due to pendingResponseID:0x1bAny information what this means?
February 2, 2025 at 4:18 pm #187989
As an educated guess, the H90 Program is still loading via the PC when the CC message arrives, a scant few milliseconds later (if that). Another speculation: the H9 – even with an older processor – is loading less than half of data that an H90 Program contains.
I suppose it’s possible to hold incoming MIDI messages in a buffer, delaying it long enough to slide into the MIDI stream shortly after the last command has completed. As a serial protocol, you’re bound to run into some limitations with MIDI vs. the power of modern processing.
I haven’t checked back your use case with either an H9 or H90. If I need a Program (or one of its Presets) to load bypassed, I re-save it with Bypass engaged. Then use an Act/Byp command as needed.
February 2, 2025 at 4:29 pm #187990
That’s really a bother and not something I’d expect from such a high price point. I’ve noticed I’m not the only one with this use case and having to load everything disengaged and engaging it from another preset means I lose the flexibility of having one preset for each program but I would need to have 4 to cover each use case of A/B being bypassed.
I guess I’ll be returning the H90 and keeping the H9 since at it’s current state the H90 is unusable for my purposes.
February 3, 2025 at 12:19 pm #187999
We are aware that there is an issue with this use case and are working on a solution. Previous versions of the firmware should allow you to use the simultaneous PC+CC messages, or if you use Program level active/bypass mappings (not global active/bypass mappings) then that should work as well.
I’d be happy to help you with this further if you email support@eventideaudio.com.
February 4, 2025 at 1:03 am #188004
I note that ‘previous versions of the firmware should allow you to use the simultaneous PC+CC messages‘. Is there a previous version of the firmware that will do this that does not also have the issue where presets would load with the wrong delay time (AUD-74364)?
February 3, 2025 at 1:49 pm #188001
Just to comment that the Program level active/bypass does not work when sending PC+CC messages. I have tried it several times. No CC messages get recognised after sending the PC. I will contact support.
Apparently it should work with firmware 1.8.6. I’ll try downgrading it and confirm.
February 4, 2025 at 12:47 am #188003
I logged exactly this problem with Eventide support on 24 January. It’s a pretty big deal for me, also.
February 4, 2025 at 6:13 am #188006
I can confirm that the MIDI switching works with 1.8.6. At least from initial testing. I’ll have to check if it causes any audible difference or lag when using it in a signal chain.
February 19, 2025 at 1:23 pm #188231
I also logged this issue, last year. It makes the H90 somewhat unusable and I am back to using my Strymon pedals because they work properly with MIDI.
February 19, 2025 at 1:38 pm #188235
Sorry to hear this has stopped you from being able to use the H90. To clarify, after looking into this issue further we have confirmed that a simultaneous MIDI PC+CC will work correctly on the previous firmware version 1.8.6. We are looking into a fix for this for a future update. If you’d like to downgrade your pedal, please email support@eventide.com and I can help you do that.
April 29, 2025 at 2:42 pm #189859
I don’t suppose this has been fixed in the latest release (released today)?
April 29, 2025 at 3:25 pm #189865
Sorry, this has not yet been fixed. Changes and fixes are always listed in the release notes that you can find in the app before updating.
We do realize that this feature is important and are working on a fix for a future update.
March 13, 2025 at 5:15 pm #188925
Just an update: H90 edit now doesn’t work. It only tells me that a software update for the H90 is required and won’t let me into the preset editor. So basically I have to chose if I can use the pedal the way I intended, or if I want to use the editor.
This makes it somewhat useless, doesn’t it?
March 13, 2025 at 5:21 pm #188926
I understand that you need version 1.7.11 of the H90 edit to use the previous firmware, not the latest one, but I can’t download the previous version of the editor.
March 14, 2025 at 8:42 am #188934
Sorry for the confusion. If you email support@eventideaudio.com I can get you the correct version of H90 Control.
March 15, 2025 at 7:20 am #188956
Thank you for the continued support.
In conclusion I will be selling my H90 because the poly pitch just doesn’t work as well as my Line 6 devices. I wanted it to replace my H9 but the ease of use of the editor on that pedal is so much better than the H90 control. This is of course preference but along with all the other issues a dealbreaker for me.
April 12, 2025 at 3:33 pm #189545
I tried giving it another shot before selling it but it blows my mind why there is no option to send a Midi CC to have it ON at 127 and OFF at 0, or at least like the H9 did have the option to assign one CC to ON and another to OFF. The only option is to toggle, so if I’m using a switcher I have to know exactly what sequence I’ll use to turn it on or off.
Absolutely unusable
April 14, 2025 at 8:57 am #189557
This is certainly possible, please see the tip from the user manual here: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/appendix/global.html
April 14, 2025 at 9:47 am #189561
Then it doesn’t work with the firmware version 1.8.6. that allows additional values to be recognised by the device after a PC change.
I tried sending 127 to “P Act/Byp” and it will change the state from say bypassed to active. Sending 127 on the same CC again bypasses it from active. I would expect by the manual that 0 would be bypass and 127 active, but 127 just toggles it. So there is no way to definitely send a value for Bypass.
Using “P Act/Byp (M)” does the same but only activates it for a brief moment.
April 14, 2025 at 11:15 am #189563
This behavior has not changed throughout different firmware versions.
What is the MIDI controller you are using? From what you describe, it sounds like your MIDI CCs are momentary; they send a high value when the footswitch is pressed and a low value when it is released.
You need your MIDI controller to only send the specific high or low CC value, then it should work correctly for discrete active/bypass messages when using P Act/Byp (M).
April 14, 2025 at 11:20 am #189564
In that case the other MIDI devices I have would have the same issue, but they don’t. I use a Strymon and a Line 6 device with the same EFX LE controller and none of them have the issue. All of them have the same CC logic where 127 is on and 0 is off.
April 14, 2025 at 11:30 am #189565
I’m sorry, I don’t have any further information to provide.
As described above, you need to use P Act/Byp (M) and you need your MIDI controller to only send the specific high or low CC value, then it should work correctly for discrete active/bypass messages when using P Act/Byp (M). Many users use the H90 with MIDI this way.
April 14, 2025 at 11:33 am #189566
That’s ok, I’m just stating the issues I was having in case someone else has reported the same issue. The same issue persists with the Tuner function, sending 127 activates the Tuner, sending 0 does nothing. I have to send 127 again for it to deactivate.
May 15, 2025 at 5:49 am #190164
Is this problem still not solved?
May 15, 2025 at 9:37 am #190165
This problem is not resolved in the latest firmware version. We’re working on a fix for the next update.
If you need help getting to the previous firmware version to use this function, please email support@eventideaudio.com and we can help you there.
May 17, 2025 at 11:05 pm #190201
Stroboscapes – I was just updating my new (SECOND) H90 tonight and was in H90 control thinking, “where’s the interface for individual preset tempo?” I thought it was user error, but yes, I second what you wrote!
May 26, 2025 at 5:36 pm #190339
Yeah I know, and it’s very unfortunate. I love my H9 and thought this would solve many problems for me, but the H90 had by far the most unintuitive user experience both with the editor and on the pedal itself. I expected a lot more on a 1000+ EUR pedal
I’d be happy to give it another shot if it becomes more user friendly with future updates, and the pitch algos improve. But for now I went back to my H9 and added an HX One for the pitch and other effects I wanted the H90 to do.
October 10, 2025 at 12:53 am #192538
This problem has not yet been resolved.My firmware is up to date.
October 10, 2025 at 8:16 am #192544
The problem has not yet been addressed.
This post will be updated when the issue is resolved. Until then, do not update your pedal if you need this function. You must remain on the previous firmware version for now.
Sorry for the inconvenience.
October 12, 2025 at 1:51 am #192554
It’s been over a year since this issue started. There have been several updates, so why hasn’t it been fixed? Is the cause unknown?
I’m sure this is causing problems for people who use MIDI control.
I’ve recently started using something other than the H90 because this issue hasn’t been resolved. I’m waiting for it to be fixed.
November 10, 2025 at 9:45 pm #193225
Instead of starting a new thread, I’m experiencing a weird/similar issue. Using a Morningstar M6 Pro. When I send a PC message 1 for my program 1, it loads the program and activates the program. This seems to be correct behavior. However, when sending PC message 2 for program 2, it loads the program but does not activate the program. I also have a CC message set up to act/byp (M), or the other one, I forget, but it’s bypassing the program as it should.
So, program 1 (and I tested it on program 3), using the corresponding PC message, will load the program and activate it. But, for some reason program 2 does not work the same way. I double, triple checked my simple midi message and other than the PC message being 1, 2, or 3, there is no other difference.
So, I went back into H90 control, and I saved program 2 with an “active” state… After doing this, then PC message 2 now loads program 2 and activates it.
Is this normal behavior? You have to save your program in the “active” state for it to respond correctly to the PC message of loading and activating? It took me like 2 hours of back and forth almost ready to give up, until I figured this out.
To the OP, if you want to load a program using the PC message, but have it in the bypass state, maybe try savings your program in the opposite state of what you want?
December 26, 2025 at 7:13 pm #194067
Instead of starting a new thread, I’m experiencing a weird/similar issue. Using a Morningstar M6 Pro. When I send a PC message 1 for my program 1, it loads the program and activates the program. This seems to be correct behavior. However, when sending PC message 2 for program 2, it loads the program but does not activate the program. I also have a CC message set up to act/byp (M), or the other one, I forget, but it’s bypassing the program as it should. So, program 1 (and I tested it on program 3), using the corresponding PC message, will load the program and activate it. But, for some reason program 2 does not work the same way. I double, triple checked my simple midi message and other than the PC message being 1, 2, or 3, there is no other difference. So, I went back into H90 control, and I saved program 2 with an “active” state… After doing this, then PC message 2 now loads program 2 and activates it. Is this normal behavior? You have to save your program in the “active” state for it to respond correctly to the PC message of loading and activating? It took me like 2 hours of back and forth almost ready to give up, until I figured this out. To the OP, if you want to load a program using the PC message, but have it in the bypass state, maybe try savings your program in the opposite state of what you want?
Thanks for the suggestion, but in that case if I wanted to load the preset active for one song for the first time, and in another bypassed, I would need to save two presets.
Not sure if the new update with the Granular effects fixed the MIDI issues, I have moved on to use a Line 6 HX One, which has much better MIDI implementation and Polyphonic pitch shifting. I would hope so, otherwise it would be either use MIDI without issues with a previous firmware, or use the new effects.
December 26, 2025 at 7:15 pm #194068
The issue has not yet been fixed but its on our todo list. Once the issue has been fixed, it will be listed in the release notes. Sorry for the inconvenience.
December 26, 2025 at 7:16 pm #194069
Do you also intend to fix the Poly pitch programs?
December 27, 2025 at 9:15 am #194072
Sorry, I’m not sure what you are referring to.
This forum thread is for users who are having issues with simultaneous PC+CC midi commands.
If you are having a different issue, please create a new forum topic so we can keep things organized.
