Home › Forums › Products › Stompboxes › Down envelope filter sweeep?
- This topic has 3 replies, 2 voices, and was last updated 2 years, 10 months ago by
NicholasBT.
June 21, 2023 at 4:57 pm #172084
Hi! How can I get the H90 to do a envelope filter with a downwards sweep? (Starting open and then closing)?
if it is not possible, I think it is an important update for it to have (bass player needs here hehe)
June 21, 2023 at 5:47 pm #172085
It might be time to get that feature request ready. This type of ‘Mutron Down’ idea has come up before.
There are the Octaver filters, if you want to crack the rafters. That will double your bass down another 1 & 2 octaves.
For the time being, you might want to try out HotSawz. Fast Attack; slower Decay, over the resonant filter, with a sawtooth voice (or six). I use that almost like parallel compression, with dry alongside the generated synth voice.
That might work out well with a (monophonic) bass line. I do find it to be very forgiving with perfect intervals, though. With the occasional glitch when HotSawz is trying to ‘find’ the fundamental pitch.
June 21, 2023 at 6:07 pm #172086
Actually, now that I think about it (always a dangerous proposition) …
I wonder how feasible it is to add switchable routing to the HotSawz algorithm? Process the input signal, or process the generated sawtooth oscillators.
You’d probably need to defeat or modify some of the controls (Mix Ranges; Osc Depth becomes detuning: Gate). Without knowing the R&D particulars, it seems like an easier route to repurpose what’s already there.
In a nutshell, configurable resonant filter processor for the input – OR – for the oscillators. Sounds so simple from an outsider’s POV, doesn’t it?
July 2, 2023 at 10:00 am #172251
Yes, no brainer that we can choose the direction of the envelope. Should be quite an easy addition to do. How can we get Eventide’s crew to pay attention to this?
