Home › Forums › Products › Stompboxes › Brian May Patch -H90
- This topic has 5 replies, 3 voices, and was last updated 8 months, 4 weeks ago by
Securb.
September 15, 2023 at 1:32 pm #174181
There was a Brian May-like patch that sounded like his guitar on the Flash soundtrack that I cannot find on the H90. I remember using it on the H9. If anyone remembers the name, I would appreciate it.
Also, if you know of any other Brian May-like patches I should check out I would appreciate the help.
August 1, 2025 at 4:18 pm #191332
Im looking for the same I cant seem to get the tones I want from the diatonic algorithm
August 1, 2025 at 4:18 pm #191333
August 2, 2025 at 12:48 pm #191346
I don’t know what everyone’s tried or heard before in Diatonic. Of course it’s important to select the matching Key & Scale, and the harmonies desired in Pitch A & Pitch B. Stick to single-note lines and simpler double-stops. But it’s equally important to simulate the multiple guitar overdubs.
Add up to several dozen milliseconds of delay time, with Delay A offset in time from Delay B (and also from your dry guitar). Balance between the harmony voices with Pitch Mix. Use an EXP pedal to slightly vary Pitch Mix to either side of center at A10+B10. That will a little greater emphasis on one or the other ‘overdubbed’ voice.
Here’s a quick example I tossed together that may give you a head start. Quant is OFF in Diatonic, for more forgiving string bends & wider vibrato. The Weedwacker instance in Series is optional. I just used it to push the midrange, and add some hair to the output.
August 2, 2025 at 2:51 pm #191350
After a little more thought & refinement … I attached a Program here to get you started.
- The three HotKnobs adjust the effect mixes, delay times and distortion components.
- EXP pedals vary the Pitch Mix in a subtle way, or add Feedback to the delay lines.
- AUX or HotSwitches change up harmony intervals, for 3 variations on the base Program set.
I like the idea of using momentary switches to do hammer-ons & pull-offs, much like a Digitech Impossible or HammerOn pedal can do. They’re easily accessible, and help to break up the static nature of the ‘overdubbed’ guitar voices.
A bit of pre-H90 overdrive doesn’t hurt the emulation.
August 3, 2025 at 1:20 pm #191362
Wow Thank you SO much!
Fred
August 5, 2025 at 2:13 pm #191402
Cool to see this thread pop up. I found the patch and used it on our album last year. It is at around 1:58 on this track
