- This topic has 5 replies, 3 voices, and was last updated 1 year, 9 months ago by
tfruehauf.
July 14, 2024 at 12:50 pm #183735
The Blackhole automation curves work only, if the project has very few tracks. If there are more tracks, the automation works only for the actual start value and dosn’t follow the curve. Is there any workaround or other solution? This is very important for me, because dynamic movements in space are part of my project.
Tank you
Tonio
July 15, 2024 at 9:42 am #183741
Sorry for the issues you are having.
What product are you using? The Blackhole plug-in? Or a hardware unit with the Blackhole algorithm?
July 15, 2024 at 10:09 am #183744
I use the plugin, newest update.
My DAW:
Windows 10, 64 bit, 32 MB, AMD Ryzen 5
I run a projekt with many plugins for a full VSL orchestra and all automation works fine except Blackhole. If I stop the transport and set the cursor manually to a certain position, the value of the automation curve is read. However if I run the project, nothing moves even after I stop the transport it stays at the start value. I think, there is a timing problem, it just doesn’t get the automation values fast enough.
Thank you for your support,
Tonio
July 15, 2024 at 11:23 pm #183758
You are probably better off asking in the plugin forum, where people using the plugin will see it. This forum is targetting the hardware units like the H9000
July 16, 2024 at 4:03 pm #183816
I’ve moved your post to the correct forum.
Can you please email support@eventideaudio.com with a screen recording that demonstrates the issue?
It would also be helpful to get your plug-in information by control+clicking the Eventide logo in the plug-in UI and selecting “copy support information to clipboard”. Please include that information when you email support.
July 17, 2024 at 11:49 am #183834
I found a solution:
Blackhole in my project was scaled to 125% and I found out that I wasn’t was not able to change scaling via settings. So I created a small project with Blackhole. There it was possible to rescale the plugin to 75%. Afterwards I reloaded my original large project and Blackhole surprisingly was set to 75% too and now automation follows in realtime!
Very strange, the scaling should be defined for each project separately…
