- This topic has 50 replies, 13 voices, and was last updated 1 year ago by
chrisrosspro.
September 4, 2020 at 2:20 pm #116079
Hi all,
I was wondering whether Eventide would consider offering an add-on card equipped with preamplifiers (2 channels/4channels or 8 channels) for the H9000. It seems there is plenty of space inside the H9000 for such a card and, maybe most importantly, plenty of demand. The preamps of the H8000FW play a significant role in its sonic character and they are very handy in many cases so I think it would be a great addition and definitely a great selling/marketing point.
What do you think?
September 4, 2020 at 3:17 pm #155704
I’d like this. If it could include hi-z in and out, that would make it even more valuable. I think a lot of people want plug their guitar directly into the unit, like an H9. Also use it as a DI, and be able to send directly to an H9 would be sweet.
September 4, 2020 at 7:29 pm #155706
+1 on this, even though I probably wouldn’t use it this way. Would be nice to know I have another 8 mic pres in. Would also need 48v power.
September 7, 2020 at 3:17 pm #155733
this is now ticket #H9000-390 "expansion card request: mics and Hi-Z inputs"
I've always thought that a mastering-grade mixing-link-type expansion card would be sweet.
September 8, 2020 at 2:24 pm #155740
Looks like a great idea! I hope the mic pre’s will include a direct out, bypassing the unit’s digital conversion, for when that is not needed, like when going directly into an analog mixer and adding H9k FX via mixer sends.
September 11, 2020 at 5:07 pm #155777
This is such a good idea. +1!
September 26, 2020 at 2:58 am #155912
Absolutely +1. I’m keeping my DSP-7000 around mainly for the unique sound of cranking the pre’s.
January 25, 2021 at 6:17 pm #156943
Bump.
How is this coming along? Can anyone from Eventide comment on this?
January 25, 2021 at 8:25 pm #156945
Ticket #H9000-390 “expansion card request: mics and Hi-Z inputs” has yet to be assigned to anyone. Development is currently focused elsewhere.
Edit: Nevermind! This actually is in progress, but I have no specs nor timeline for it.
Great! Thanks for revealing that much.
I’d like to request that consideration be given to incorporating XLR/TRS combo jacks on that expansion card. Should I create a ticket? Actually, what is a ‘ticket’?
January 29, 2021 at 5:10 pm #156977
Tickets are a part of Eventide’s internal project tracking system, which users don’t have access to. Rest assured that your comments have been noted.
Thank you.
January 30, 2021 at 8:10 pm #156991
I would happily purchase a card with great sounding preamps. I’m currently keeping my DSP-7000 around cause I really like the sound on the analog inputs when tracking synths. Would love if the H9000 can cover that final bit of ground.
January 31, 2021 at 4:47 pm #156995
Add my name to the list of someone who thinks this would be a great add-on!
February 1, 2021 at 6:04 pm #157007
I know it’s still very early in the process, but how would you envision this card working if someone is currently using the analog I/O on the H9000?
Would we simply move the DB25 from the current input section to the new card, or would the card give us an additional 8 analog inputs (for a total of 16 in x 8 out analog)?
thanks
February 1, 2021 at 11:01 pm #157008
I might be overlooking something, but I don’t see the point of moving the DB25 from the current input section to a new card. Hmmm
As for a new card expanding the number of inputs, surely there are people who would appreciate that. For such a card to add 8 channels, in consideration of the horizontal space available, it probably would have to have a DB25 connector.
Another card could offer a fewer number of XLR/TSR inputs. Those could either add channels or be alternatives to the existing 8 channels. (UAD’s Apollo x8p has both DB25 and XLR/TSR inputs for the same 8 channels. The user can select in software which is used.)
Offering multiple types of analog input expansion boards would be relevant to the H9000 as a long runner.
February 2, 2021 at 3:01 am #157011
I think (but I could be wrong) what he meant by ‘move’ was the output of the preamp card would connect via DB25 to the analog input section of the H9000. This saves the cost of a separate ADC if the preamp card cannot be routed to the existing analog section internally.
February 2, 2021 at 2:57 pm #157021
Yes, my summary question is — if we install the pre-amp board, do we now have 16 separate analog inputs or still just 8?
I guess it may come down to whether the pre-amp board has its own A/D converters or does it plug into the existing analog bus and use the converters already present.
I think it would be a lower cost if it used the existing converters and was purely a pre-amp analog board. We wouldn’t have lost anything (still have 8 analog inputs) and if they use a DB25 connector for the new board, it’s simple matter of installing the board and attaching our existing DB25 connector to the new board instead of to the mainframe.
The card will have its own converters and it will create additional analog channels, independent of the 8 channels of IO built into the main board, so yes, with one of the cards installed there will be more than 8 analog inputs. (You can also add multiple cards for more analog channels if you have free expansion slots).
February 2, 2021 at 5:00 pm #157025
[/quote]
[/quote]
Very nice! Now about that internal fan…….
February 2, 2021 at 7:26 pm #157029
This can potentially open up a whole new class of channel strip like algorithms, not quite modeling like UA and others but with character all their own. 8 mic pres would turn the H9000 into a more viable stand alone interface. I understand it was never the intention, but this can definitely work. Maybe down the line we can have an interface mode tab, with the ability to send from these 8 pres to other algorithms. Lots of possibility here.
February 3, 2021 at 8:47 am #157050
+1 on this idea – although 4 channels would be enough for the majority of my projects.
February 4, 2021 at 2:09 pm #157067ThreeFingersOfLove wrote:
Hi all,
What do you think?
i still have my orville in the rack (with the 9000..) for this very reason – very much would like to see this happen.
r
June 12, 2021 at 11:16 am #158087
Hoping this is making its way up Eventide’s to-do list.
Big ‘yes’ to preamps!
June 12, 2021 at 12:27 pm #158088
I would like to know as well, if there’s any progress with this.
June 12, 2021 at 2:01 pm #158089
I would love this myself
June 13, 2021 at 8:31 am #158093
Glad to hear this is in process now. I definitely would love one!
June 29, 2021 at 7:27 pm #158171
In a similar vein, I’d like to have an add-on card that will give me another 8 channels in and out over DB25.
October 16, 2021 at 6:40 pm #159503
Any news on this preamp card?
October 16, 2021 at 10:47 pm #159505
Surely this is a moneymaker for Eventide. Wouldn’t that make it a high priority project? 🙂
October 22, 2021 at 10:19 pm #159736
I’d probably look at getting one of these as well. I’m torn between going MADI or Dante for a second card. I don’t have either yet, but am going to have to go that way for any future channel expansions.
September 6, 2022 at 2:22 pm #165365
I’d be interested in the pre-amp card as well. Interested to see what turns up.
February 25, 2023 at 10:35 am #169412
i recently added a dante card (with an RME digiface..) and i very quickly realize how important these additional analog i/o cards are – wondering if there’s any update on when they might be released..
(also, the start of the thread mentions ‘inputs’ only.. but, it would for sure be great to have both ins AND outs represented..)
i would put a vote in for a card that was two dsub connectors – 8in/8out, just like whats already available on the unit, with the addition of preamps on the way in.
thanks for making such great / inspiring stuff, ET.
July 27, 2024 at 2:56 am #184036
This! Absolutely…
Just like Merging Hapi add on mic pre cards
If using Dante or MADi in studio or especially Live with digital mixers like A&H SQ series this type of Analog Card would add additional high quality AD/DA conversion + great Mic pres… so total of 16 analog Ins and outs added to the setup.
And let’s not forget that USB on H9k is 16/16 in out, so H9k fitted with 16/16 analog ins and outs makes true sense (even if it would be just the same as the provided AD/DA on the unit and Dsub 25 connectors are absolutely the best option, fitting nicely on the exp card) -
July 27, 2024 at 12:37 pm #184044
Dsub would be nice for studio use but I hope it can also have combo XLR/TRS/TS mic/line for gigging. I’d be curious to know if this analog I/O expansion card is still something Eventide is looking into.
July 27, 2024 at 2:35 pm #184047
I wonder if development costs and sales uncertainty have relegated this potential card to ‘someday, perhaps’ status. Would some sort of crowd funding be a feasible way forward?
August 29, 2024 at 3:35 pm #184584
Given the space constraints, I think the best setup would be one DB25 port and 2 combo XLR/TRS/TS ports. Ideally they would all be separate for 10 total channels, although could also make sense to have it work like the existing DB25 and XLR inputs where they overlap. For setting gain and toggling phantom power, perhaps a new section could be added to the H9000 SETUP panel in Emote.
August 30, 2024 at 4:18 am #184586
…i’d be in for a pres-card too!
August 30, 2024 at 9:07 am #184588
As soon as Eventide puts this out, I’m snatching this. Yes Please!
August 30, 2024 at 1:53 pm #184591
Hope someone at E is keeping a list. If so, put me on it, please.
October 18, 2024 at 3:34 pm #185505
I’d be curious to hear from those that mentioned extra analog outputs to know what the use case is there beyond the existing 8 channels of analog output.
The expansion card slot offers very little room so personally I think this card should focus on adding something that doesn’t exist currently (pre-amped inputs) as opposed to increasing the number of something that does exist (analog outputs).
– One DSUB connector
– Two combo XLR/TRS/TS jacks
– Two TRS/TS jacks
That should fill up the space and offer 12 pre-amped inputs with flexibility for different cable types.
October 18, 2024 at 3:52 pm #185506
i think there would be so many different use cases for these additions..
i would love 8 more ins AND 8 more outs (both over DSUB..) and don’t currently have much use for preamps built in.. or TRS inputs.. (although a card with 2, 4, or 8 TRS/XLR combo jacks WITH preamps built in could be pretty appealing to many) ((8 might be a stretch though..))
maybe different cards could be offered – kinda like apogee does with symphony… so you’d be able to pick from a few options that best suited your needs..
i’ve looked into some of the RME stuff for this exact reason (more ins/out..) over MADI.. but, i’ll wait it out if i knew what was (and wasn’t coming..) from eventide!
still happily using the H9000 everyday (and orville, as well..)
r
October 18, 2024 at 4:19 pm #185507
Curious for some examples of what would you do with the additional 8 analog outs
October 18, 2024 at 4:27 pm #185508
i’d say mostly for live processing..
right now the H9000 is used for my solo guitar setup..
i’m using a 10 channel (6 mono, 4 stereo) mixer and all 8 outs (from the 9000) are plugged into the 4 stereo channels..
but…. there’s some synths / modular around that i’d also like to be able to process with the 9000 and send to their own channels on the same mixer – the additional cards would make this possible..
October 22, 2024 at 12:39 am #185582
I will be happy having a card for 8 Ch of Analog I/o and 8 CH AES
October 31, 2024 at 12:51 am #185926
more analog cards please!!
November 2, 2024 at 2:46 pm #185996
I would love Analog Cards:
-8 Ch I/O for more Inserts
-16 Ch Out for Playback
April 7, 2025 at 9:40 pm #189471
just checking in on this thread – any updates of when this might be happening?
would love to see it!
r
April 8, 2025 at 11:31 am #189478
Interest continues. Hope Eventide is actively working on this.
April 8, 2025 at 12:07 pm #189479
April 23, 2025 at 10:25 pm #189712
Hope this is still in the works! Love my H9000, H90, H9s and software madness!
